Old 05-24-2018, 01:05 PM   #1
clutch slave access
Finished bleeding the brakes and now doing the clutch. Wow, is that thing hard to get to. What's easier, reaching up from underneath the car (on stands, not a lift) or reaching in through the hole behind the left rear wheel. I'd like to make this as painless as possible -- if that's at all possible.
jandr95 is offline   Reply With Quote
Old 05-24-2018, 01:39 PM   #2
steved0x's Avatar
The times I've done it, it was on stands and I did it from under the car.
Old 05-24-2018, 02:26 PM   #3
Ciao's Avatar
I reached it from underneath with a small size wrench
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 05-24-2018, 03:28 PM   #4
On stands and mostly by feel. A power bleeder makes it a lot easier than having someone else pressing the clutch pedal.
1941 Dodge Luxury Liner Coupe
Old 05-25-2018, 04:32 AM   #5
still plays with cars...
BoxsterSteve's Avatar
As mentioned, on stands, shorty wrench operated by your left hand from the left side of the transmission.
Position yourself so you’re lying under the car with your legs sticking out the right side of the vehicle.
Six speed 2000 Boxster S
Old 05-25-2018, 05:24 AM   #6
Maybe its cause I have an aftermarket exhaust, but I had no issues reaching this from underneath.
