Old 01-16-2018, 07:48 AM   #1
2000 Boxster - gauge cluster removal - please help
Folks, on my car the key was getting hard to turn from off (0) to accessory (1) position. Especially when it was colder outside and/or the key hadn't been turned in awhile.
I first replaced the electrical portion of the ignition switch, but that did not help at all.
Next, following the guidance in the pelican tech article (86-ELEC-Replacing_Your_Ignition_Switch_Steering_Lock.htm) ...my goal was to replace the mechanical portion of the ignition switch (aka pistol steering lock assembly).
To do that, you are supposed to remove the dash/gauge cluster first.
I was not able to get that done unfortunately. The instructions stated "D: Lift the gauge cluster up so that you can disconnect the wire harnesses on the back.".........but in my case I couldn't get the thing to lift off far enough (it seemed stuck on something I couldn't see on the driver's side moreso --- i'm guessing the wiring to the 3 cable harnesses on my car just didn't have much slack).
I had to decide on whether to just keep tugging away until it gave or to stop and avoid more $$ damage and chose the latter.
Any tips on how this gets done for a beginner? I'm going to be forced to take it into the dealer it seems if I can't figure this out.
ben2000 is offline   Reply With Quote
