Old 12-28-2017, 08:19 PM   #1
Transmission swap
Could I use the automatic transmission from a Boxster Base to a Boxster S? I have the 2 cars, I want to keep the Boxster S but the transmission is damaged. I want to swap the transmission from the 2.7 engine to the 3.2 Boxster S. Is it possible?
carlosnolasco is offline   Reply With Quote
Old 12-28-2017, 09:53 PM   #2
This might help...
See here: https://rennlist.com/forums/boxster-and-boxster-s-986-forum/116152-boxster-tiptronic-vs-boxster-s-tiptronic-transmission.html
Old 12-29-2017, 06:06 AM   #3
Thanks for the information, a little confuse but this the best that I found already. In your opinion, Could I swap it?
Old 12-29-2017, 08:58 AM   #4
78F350's Avatar
The axles that fit the 2.7L car bolt to a different size coupling than the 3.2L car and the wheel hubs are different. I expect that it can be done but not as a simple exchange of just the transmission. It may be simpler just to swap parts from one transmission to the other.
Old 12-29-2017, 01:08 PM   #5
Thanks, that is more clear for me now. We open the transmission and found a lot of metal inside and the PLANETARY GEARS has some broken parts and also something that looks like a solenoid is cover with some metal flakes, I need to see if I can post pictures to explain better the situation. I am not sure about the name of some parts, just googling to ask the questions.
