Old 11-01-2017, 11:52 AM   #1
1998 Boxster Silver/Red
Struggling with front engine lid.
I've removed all the nuts from the lid, including the two in the center. It would appear that it would just lift/pop out. The exact opposite. I've tried tugging... pulling... and when I got to prying with the screwdriver I thought I'd better turn to minds far sharper than mine.
Is there a seal behind the lid that, maybe, snugs it into place? Should I just grab a corner and pull with all might? It's like there's a force pulling in into the engine compartment.
I'm not in a pinch... just wanted to take a peek at the belt and other components.
Thank you in advance.
Old 11-01-2017, 12:34 PM   #2
Should just pull straight off. Try prying gently...
clickman is online now   Reply With Quote
Old 11-01-2017, 01:27 PM   #3
The Radium King's Avatar
there is a rubber gasket between the cover and the bulkhead that can 'adhere' pretty aggressively. pull off and hope for the best.
Old 11-01-2017, 01:44 PM   #4
Thank you. That rubber gasket was aggressive. I simply employed some of that patience I've been reading about.
Old 11-01-2017, 09:10 PM   #5
Pdwight's Avatar
For the future
Never use a screwdriver, invest 10 bucks in a set of trim removal tools.....you find lots of uses for them
Old 11-02-2017, 03:08 AM   #6
LOL. Yes...I should. And, I will. For soooooooooooooo long I've meant to pick up a set, even when at Harbor Freight. Always forgetting... turning to screwdrivers wrapped in a cloth.
I'll be picking up those tools. Today. Thank you for the inspiration.
Cheers!
Old 11-02-2017, 03:52 AM   #7
I find that you sometimes there’s a clip holding on even after you’ve unlatched them. I get my fingers under it and shake while I lift up on it. That will usually loosen them up as you’re pulling up.
Woody
