Old 10-29-2017, 05:46 PM   #1
98Sixer's Avatar
Coolant Leak
Pulled up to the house after running some errands and noticed some fluid from under the car as it was still idling. Initially, thought it was condensation from the A/C, but did not have it turned on.
Definitely coolant as per the photo. Enough to run down to the curb and pool.
Shut the car and then started her up and nothing...not another drop. Worth mentioning that upon start up I hear a high pitch whine that goes away after a minute or so.
Is this an intermittent water pump on the way out or something else? Water Pump was replaced 14,000 miles/3 years ago.
Any insight would be appreciated.
1973 914 2.0-Marathon Blue Metallic (Funday Driver)
1972 VW Beetle Convertible-Saturn Yellow (Sunday Driver)
2013 Panamera S Platinum Silver Metallic (Daily Driver)
2002 Boxster 2.7-Lapis Blue Metallic (Don't Even Ask!)
98Sixer is offline   Reply With Quote
Old 10-29-2017, 06:57 PM   #2
Ciao's Avatar
I get the same whine every time I start her up; last for about a minute or two then goes away.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 10-29-2017, 07:01 PM   #3
The noise at start up is your air pump. It is normal and has nothing to do with your leak. After your car cools, check the coolant level in your reservoir. Also, pull the cover behind your seats, start your car and look for leaks around the water pump. Be careful!
Old 10-29-2017, 07:02 PM   #4
BTW, air pump runs for 75 seconds at start up IIRC.
Old 10-29-2017, 07:25 PM   #5
98Sixer's Avatar
So the coolant was previously sitting at the minimum line and is now about 1/2" below. I have the engine cover off, but honestly have no idea as to the pump location. My other P-Car is air cooled so don't have to deal with this sort of thing.
Where exactly should I be looking. I can see the two rubber hoses, should I just shine a light down or will this become apparent on starting?
Old 10-29-2017, 10:49 PM   #6
oldskool73's Avatar
for the water pump, you want to open the access in the firewall behind the seats (not the one at the back under where the roof folds), then look around the bottom left pulley, that runs the water pump. This is what you'll be looking at when the cover is off, and you want to check #4 http://cdn4.pelicanparts.com/techarticles/Boxster_Tech/05-BASICS-Belt/images_small/Pic3.JPG
oldskool73 is offline   Reply With Quote
Old 10-30-2017, 11:11 AM   #7
kirkandorules's Avatar
Leaking water pump (or hoses that connect to it) can also cause a cloud of white vapor to come out through the passenger side engine bay fan vent.
'99 986 Ocean Blue Metallic
'87 924S, winter beater
'17 VW Golf Sportwagen, for when I need extra seats
kirkandorules is offline   Reply With Quote
Old 10-30-2017, 11:47 AM   #8
98Sixer's Avatar
Thanks for the diagram link from Pelican, that helps. The problem is intermittent so I dropped it at the shop for them to sort out. Didn't leak or have temp gauge go above 180 on the drive over. Could be an expansion tank issue as well.
