Old 09-23-2017, 10:32 AM   #1
Door speaker question
Hey,
I did a bit of googling, but couldn't find any answer to this so I figured I'd ask here.
Does anyone know if it is possible to replace the door speakers *without* having to remove the entire door panel? (i.e. just removing the speaker grille and mount a replacement speaker)
square-root is offline   Reply With Quote
Old 09-23-2017, 11:39 AM   #2
78F350's Avatar
No.
Look at this, particularly figure 4.
Porsche Boxster Door Panel Removal / Mirror Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 09-23-2017, 12:28 PM   #3
It is not possible. The plastic grill area does not snap into the panel...it is one assembly.
Don't let it stop you though....
Removing the door panel is very straight forward and takes 5-10 minutes, even if you haven't done it before.
Old 09-23-2017, 01:13 PM   #4
MWS
Follow the link provided for screw locations, otherwise you will I'll bet you don't find a screw. Lol...I know I didn't, and resorted to google.
Old 09-25-2017, 09:32 AM   #5
Thanks everyone!
Old 09-26-2017, 08:49 AM   #6
Ever since I swapped in the 996 cab amp the boosted bass frequently causes the door speakers to vibrate audibly. Anyone know how to fix that?
Old 09-26-2017, 09:54 AM   #7
Chuck W.'s Avatar
They may need to be tightened down. I have found the mounting screws lose on two different occasions. You would think that after the second time I would have used some Loctite on them. Oh no.... Perhaps when they loosen for the third time I will.
1995 Porsche C4 Cab
Old 09-26-2017, 11:17 AM   #8
The door speakers are not for mid/high they are basically bass speakers. The only way to improve the sound from the door speakers is to put "normal" speakers in there. WHen I changed my HU/Amp the doors still sucked but after changing them I can front/rear left/right like a normal car. I found speakers that just screwed and plugged in.
