08-21-2017, 06:16 AM
Changing brake rotors and pads
I will be changing all rotors and pads on my 986 soon and I want to know if I have to also change the brake pad sensors
08-21-2017, 06:35 AM
When I changed mine I did not change the sensors... I changed them once in 16 years
DrCactus
08-21-2017, 07:21 AM
Multi-Boxer Driver
Only if the sensors are worn (brake wear light is on) or the plastic is brittle.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
08-21-2017, 04:13 PM
For the inexpensive price of the parts, and the 5 minutes of labor to replace while doing this job, buy new sensors. You can replace them easily after the fact if you decide to try to reuse but as mentioned, its easy to brake one due to age of the parts.
You can always compromise and buy two to have on hand if you need them.
Also, if safe and possible, start your car after reconnecting what ever sensors you use (original or new) to make sure connectors are seated prior to mounting your tires....might save you a few minutes later down the road!
08-21-2017, 06:29 PM
If the brake light wear light hadn't come on, the sensor wear surface will be good.
Sent from my Galaxy S8+ using Tapatalk
08-21-2017, 07:04 PM
I find removing the sensor to be a pain in the rump. I'm guessing all the brake dust tends to seize mine in place. Maybe there is a better removal technique than to get gorilla on them (which leads to broken wires). I just get new ones so I don't have to try to keep from breaking them.
V.H. Whitley
Owner of Waaay too many vehicles
Non Porsche :1959 International B120, 1960 International B120, 2015 BMW M3
Porsche: 1997 986, 2001 986S, 1968 911L, 1968 911S, 2005 911, 1984 928, 2008 Cayenne S.
08-22-2017, 02:46 PM
Shims
Get new ones...
08-23-2017, 11:15 AM
Don't even bother with them.
If they are all good, cable tie them off and if you have a bad one, just strip the wires and solder them together.
Its easy enough to see the pads and you can see when they are worn
08-23-2017, 03:07 PM
Pull them out with needle nose pliers. Works every time. Pulling on the wires is a recipe for trouble.
1941 Dodge Luxury Liner Coupe
08-23-2017, 06:35 PM
I had trouble getting the first one out until I figured out how to do it, and ended up pulling on the wire and bending the unit, damaging it. Not a problem since I had planned on replacing them.
08-23-2017, 07:17 PM
OP, your are getting yes and no responses....and all are correct! It's up to you of course.
Either way, as I mentioned before, try to start your car and look for a light before you take the time to put the wheels back on.
