Old 07-20-2017, 07:51 AM   #21
52k Miles
I did change mine when a new clutch pressure plate was needed but the original single row small bearing showed NO signs of wear.
Jgkram is offline   Reply With Quote
Old 07-20-2017, 07:56 AM   #22
DrCactus's Avatar
93,000 KM and have not changed my IMS.... if it's not broke - ... you know the rest!
DrCactus
Old 07-20-2017, 07:58 AM   #23
03 2.7 59K original
03 986, Seal Grey, Graphite Grey, Black Top, Litronic, Cruise, OBC, Bose, 17"S-Color Crest, Alarm, PSM
BXTRBRU is offline   Reply With Quote
Old 07-20-2017, 08:06 AM   #24
1998 Boxster Owner
98 Boxster 66K - No IMS
Benitom is offline   Reply With Quote
Old 07-20-2017, 08:30 AM   #25
130,000 km on original IMS and clutch. I will likely do the LN bearing when I do the clutch, but who knows when that will be?
Old 07-20-2017, 09:53 AM   #26
'02 S, 81K miles, no IMS change. I beat it like it owes me money, autocrossed mucho, keep it at or above 3000 RPM. Someday when it needs a clutch I suppose.
2002 Lapis Blue Boxster S
navair is offline   Reply With Quote
Old 07-20-2017, 10:07 AM   #27
Ciao's Avatar
2001 Model S with 38+Miles have not and don't intend to anytime soon change the IMS
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 07-20-2017, 11:22 AM   #28
WALDMEISTER
BRAN's Avatar
+16 years
~ 55k km
Original IMS
NO ISSUES
Old 07-20-2017, 11:39 AM   #29
Perfectlap's Avatar
After 14 years of owning this car most of that time being on this forum it's my opinion that all mileage is not equal when it comes to this issue. If the miles were from daily driving where not-IMS-friendly contaminants are regularly burned off and the car is not left parked sitting in this stew, the better.
If the mileage is mostly from long stints with long periods of sitting parked with long oil change intervals...not better.
One forum member here had over 300k miles but daily drove the car for more than an hour obviously and maintained a strict oil change regiment. He said "what's an IMS?"
Old 07-20-2017, 02:31 PM   #30
heliguy's Avatar
I never changed mine. 111,000 miles before the motor blew (not IMS related). My mechanic said the IMS was pristine.
Old 07-20-2017, 03:10 PM   #31
Tom Mohr's Avatar
1999 with 55k, have owned it for 5 months and it has not been changed.
Tom Mohr is offline   Reply With Quote
Old 07-20-2017, 04:27 PM   #32
Rennzenn
j.fro's Avatar
2000 S with 188,000 miles. Owned since 2006 (60,000 miles at purchase). Heavily modded and autocrossed regularly. Original dual row IMS.
Rennzenn
Jfro@rennzenn.com
Old 07-20-2017, 04:41 PM   #33
07 Carrera S Cab
Boxtaboy's Avatar
01 986. Original IMS. 73k miles. Oil change every 2 yrs.
Old 07-20-2017, 08:00 PM   #34
00S 133K miles = No
Old 07-21-2017, 10:18 AM   #35
kk2002s's Avatar
95k+ miles, still on original. The bad one, single row 2002. I have started to see a few drops at the infamous motor/trans joint since last winter's oil change, only after I drive it for distance. I think it's RMS.
So would one be an utter fool to just change RMS and clutch???
I am to much of a perfectionist not to take advantage of the trans drop and change out the IMSB at the same time
Seal Grey
Old 07-21-2017, 10:34 AM   #36
1999 base with 62,000 miles on a replacement engine. (replaced in 2003) I'm not sure if I have a double or single row bearing. I had the clutch replaced 20,000 miles ago along with the RMS and IMS cover only with the updated version. If I ever need the clutch replaced again I will probably get the IMS bearing done at the same time, but will replace it with the Pelican Parts version.
springer123 is offline   Reply With Quote
Old 07-21-2017, 10:50 AM   #37
Here's a Poll on IMS done not too long ago.
http://986forum.com/forums/boxster-general-discussions/65466-survey-failed-ims-replacements.html
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 07-21-2017, 02:12 PM   #38
1997 Tip, 2018 Macan
rexcramer's Avatar
97 Tip, 26,000, original.
Old 07-21-2017, 03:07 PM   #39
37k on the replacement motor put in the car weeks before I purchased it without an IMS change.
I drive it like I stole it too. Every single time I take the car out of the garage.
I have decided that life is short and I am going to drive a Porsche like a Porsche and not worry about what might fail.
Hey, if I can get the motor to implode one way or another, I have an excuse to put a big Chevy V8 in it and start street racing doctors in turbos!
Old 07-21-2017, 03:16 PM   #40
My Cousin has a base 1999 with ~ 90k miles. The only thing he has done was pay the dealer to tweak the top when it was out of sync. He has never visited this nor any other Boxster Forum and couldn't care less, He just drives it.
I wish I had his non-interest perspective. I replaced the IMS bearing (on my old 2002 Boxster S) at ~ 30k and the original was as tight as a drum, no pending issues whatsoever. I read, I freaked, I reacted and spent money I should not of, live and learn........
