Old 07-08-2006, 09:58 AM   #1
deliriousga's Avatar
Should I do the clutch now (maybe a performance one w/ lightweight flywheel)?
When it rains it pours.
The Boxster was out on the driveway the past week (covered of course) while I was fixing my "you used the wrong grease on the clutch bozo" problem with the 928. I'm ready to go back to diagnostics for the Boxster's idle and no power problem so I pushed her back into the garage to get ready for lifting. I look out in the driveway and there's a nice puddle of oil sitting there. After lifting her, I pulled the pans off and we have a rear main seal leak.
Since I'm going to have to pull the entire tranny and clutch out to do the RMS, should I just go ahead and replace the clutch? The current clutch has 82K miles on it but it still feels great. Also, if I replace it, has anyone put in a lightweight flywheel/performance clutch package in? How do you like it?
TIA!!
1966 Wife White/Brown Top
Old 07-08-2006, 11:05 AM   #2
At 82k mi. id definitely replace the Clutch to compensate for the whole RMS labor.
spine911 is offline   Reply With Quote
Old 07-08-2006, 11:55 AM   #3
If you are going to do the RMS I would just change out the clutch as well. A OEM clutch kit will run you about $215-280 new off eBay.
Old 07-08-2006, 01:38 PM   #4
Perfectlap's Avatar
are you using the factors RMS or are you trying the Cayenne one?
Old 07-08-2006, 02:20 PM   #5
Yup, replace the clutch while you are in there. Boxster clutch is very cheap compared to the other models. Also, you can have the dual mass flywheel turned at a machine shop that has a surface grinder (your typical auto parts store will not be able to turn it). Our shop charges us about 60 bucks to turn the dual mass flywheels.
Karl Wilen
RennsportKC
PorscheDoc is offline   Reply With Quote
Old 07-08-2006, 07:04 PM   #6
Doc-
Is there a specific step height when having the flywheel resurfaced?
Thanks,
Jim
MemphisJim is offline   Reply With Quote
Old 07-08-2006, 08:06 PM   #7
Congrats on going 82k on your clutch!
Yeah, I'd say you might as well while you're in there....Kill 2 birds at once....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 07-09-2006, 04:47 AM   #8
I don't know. Is there any proof that the Cayenne one fits properly or just rumors? I have seen other threads where people talk about "it's supposed to fit..." but I haven't seen any where someone said "I put it in and it works". If you know of any, please share and I'll consider doing that to see if it takes care of the problem permanently.
Old 07-09-2006, 08:24 AM   #9
Originally Posted by MemphisJim
Doc-
Thanks,
Jim
Nope, they usually take off the bare minimum to even out the flywheel. Usually they aren't too far off, but it is cheap insurance to make sure the new clutch disc seats properly and smoothly. IIRC the numbers that usually get marked on the flywheel are .01 or less. I think I have one sitting on my shelf that was milled .008
Karl Wilen
RennsportKC
Old 07-09-2006, 11:59 AM   #10
Brucelee's Avatar
The guy who writes the tech col. in Panorama indicated that all service shops were now using the Cayeene seal.
Hope that helps.
Rich Belloff
Old 07-09-2006, 01:34 PM   #11
Hope that helps.
Fantastic! Thanks Rich.
