Old 06-26-2006, 08:18 AM   #1
Perfectlap's Avatar
Squeal at start up?
Anyone familiar with a loud short squeal when the engine is fired up? Sounds like a belt is out of whack. Seems it Only happens when the car has been sitting for a while. I also think if I give the car a bit more gas it won't make this noise.
Guess its back to the dealer.
BORN: March 2000 - FINLAND
Old 06-26-2006, 09:00 AM   #2
Brucelee's Avatar
Yes, could be a belt.
It could also be your starter motor. I had one go bad and it would make this noise upon start up, but not every time.
Hard to tell without being there.
Good luck.
Rich Belloff
Old 06-26-2006, 09:06 AM   #3
Perfectlap's Avatar
how much was the starter motor replacement? go easy on me...
Old 06-26-2006, 09:18 AM   #4
Hi,
It could also be any belt-driven ancillary (PS Pump, AC Compressor, Alternator) with a bearing going dry/bad. Similarly, either of the Idler/Tensioner pulleys as well. The secondary Air pump can also make noise at start up. The one on my Esprit goes off every cold start for a few hundred revs until it warms and the vanes expand, but this is usually more of a chirp than a squeal. Hope this helps...
Happy Motoring!... Jim'99
Old 06-27-2006, 09:14 AM   #5
Get under there and rub a little soap on it, if it goes away for a few days, your tensioner is likely too tight. Everybody thinks its too loose but it's generally exactly the opposite.
986Jim is offline   Reply With Quote
