Old 11-07-2016, 07:11 AM   #1
Signs of transmission problems..
I've made a couple of threads about my boxster 98 2.5L
Fortunately my mechanic towed the car back and repaired the engine - which sputtered milk shake (coolant engine oil mix)
The mechanic stripped the engine and repaired it.. I haven't gotten hold of the list of items replaced yet..
My question is this: my mechanic says after the engine is repaired, the car is fine. However previously the car shakes whenever P,D,R are switched (esp after some time running) and also, when gear shifts in auto mode, the car jerks a little. I reckon those are transmission issues?
I want to demonstrate such issues to the mechanic soon to convince him the transmission has issues so he can bother to fix them...
Do you guys think the above are transmission issues or may be related to the engine? Besides obvious inability to engage gears, what are the other obvious/subtle signs of transmission issues that I should look out for?
Thanks a bunch
Sent from my SM-G930F using Tapatalk
perspectivism is offline   Reply With Quote
Old 11-07-2016, 08:19 AM   #2
78F350's Avatar
Glad to hear that you have your car back and driving again.
Is it possible for you to have a passenger record some video of your transmission issue, then upload it to YouTube or another site we can view it from? -Describe what you think the problem is, while it is being recorded.
It is difficult to determine if there is a problem based on your description alone.
Old 11-07-2016, 11:52 AM   #3
A bad (worn) engine or transmission mounts could also cause the shaking or vibration problems you are experiencing..
Old 11-07-2016, 08:46 PM   #4
Pdwight's Avatar
Possibly a new filter and ATF for the transmission....could be that simple. The Engine Mount is not a hard fix and should be done if it is the original
