Old 10-11-2016, 06:19 PM   #1
What is the purpose of this hose?
It is not on the technical drawings. It's not the hose that goes to the PCV valve on the drivers side. It connects to a hard line that seemingly has a sensor or wires at the connection then disappears with other hard lines. Where does it go?
Old 10-11-2016, 11:13 PM   #2
Does this help at all?
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
Old 10-12-2016, 06:02 AM   #3
Artist, 986S tinkerer
NewArt's Avatar
Old 10-12-2016, 06:15 AM   #4
Motorist & Coffee Drinker
78F350's Avatar
I don't think that he is asking about the primary AOS to intake tube, but the secondary tube that branches.
Old 10-12-2016, 07:05 AM   #5
Yeah the secondary tube. Haha ooops should have made my post more clear!
Old 10-12-2016, 08:24 PM   #6
Bump! Anybody know? Not sure why this stuff isn't on the technical drawings!
Old 10-15-2016, 12:07 PM   #7
According to the Pelican "Boxster/911 engine swap" article (Figure #37) the blue line (in post #4) is the gas tank vent line, so it will be attached to the vapor canister. If that's the line you are referring to that is!
1998 Boxster base, silver/red
RodJ is offline   Reply With Quote
Old 10-16-2016, 09:26 AM   #8
[QUOTE=RodJ;513179]According to the Pelican "Boxster/911 engine swap" article (Figure #37) the blue line (in post #4) is the gas tank vent line, so it will be attached to the vapor canister. If that's the line you are referring to that is!
Whooo thank you!
