Old 03-14-2016, 07:57 AM   #1
Artist, 986S tinkerer
NewArt's Avatar
very short range on remote
I've noticed that my key fob remote will lock/unlock the car only within a few feet. The battery has been changed and there's no difference. It's not a huge problem, but I saw something about an immobiliser antenna mentioned in another post. I've searched but I haven't seen any useful information on this. Anyone have any experience with this?
Old 03-14-2016, 08:04 AM   #2
Fintro11's Avatar
Take the driver side a pillar off, there is a wiring loom there should be a copper wire with a clear coating on it. Take that and put it on the outside of the loom should help a bit.
Try another battery too
Old 03-14-2016, 09:17 AM   #3
Worth a try
To increase the range a bit, hold the remote up to the underside of your chin and press the button. This uses your body as a large antenna. I read this on a thread here a while back and was very skeptical, but after trying it I was able to increase the range. Can't be any worse then holding a cell phone to your ear if you are worried about cancer.
'04 Boxster S - Basalt Black, Fabspeed exhaust and sport headers, UD pulley, Pedro's Bluetooth, 18" Cayman S wheels, Evo cold air intake, IPD plenum, 74mm TB, Ben's SSK with ICT shifter boot, Fabspeed ECU Tune.
F18febe is offline   Reply With Quote
Old 03-14-2016, 11:58 AM   #4
kjc2050's Avatar
http://986forum.com/forums/diy-project-guides/55810-diy-remote-range-improvement.html
Old 03-14-2016, 03:36 PM   #5
Luv2Box's Avatar
This does actually work. I read that you hold it to your head and the fluid in your skull that protects the brain acts as an antenna. We tried it and actually increased range by 9'.
Luv2Box is offline   Reply With Quote
Old 03-14-2016, 04:26 PM   #6
NewArt's Avatar
Does it vary depending on your IQ level?
If I get 10 feet, do I get bragging rights?
Old 03-14-2016, 04:46 PM   #7
Fintro11's Avatar
sounds like a good contest for a pca event
Old 03-15-2016, 07:04 AM   #8
Luv2Box's Avatar
You get in the Guinness Book of Records.
Old 03-15-2016, 08:34 AM   #9
2003 Base 5-speed
grc0456's Avatar
I'd try it, but I'm afraid my IQ would decrease the range
