Old 03-13-2016, 07:57 PM   #1
Porsche9's Avatar
Clutch pedal squeeking when depressed
It's been doing it for awhile now and today it seems to have gotten worse to the point that it's annoying and I want to fix it. Is this a common issue with a known fix? Is it as simple as a worn bushing or does the clutch slave cylinder need to be replaced? Thanks.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 03-13-2016, 08:45 PM   #2
Multi-Boxer Driver
Deserion's Avatar
I have the same issue (light squeak), curious as to the specifics as well.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 03-13-2016, 09:05 PM   #3
I have the same issue as well. It didn't start squeaking until I changed the clutch booster spring that I bought on Ebay. I'd be very interested to see how any of you fixed it.
'04 Boxster S - Basalt Black, Fabspeed exhaust and sport headers, UD pulley, Pedro's Bluetooth, 18" Cayman S wheels, Evo cold air intake, IPD plenum, 74mm TB, Ben's SSK with ICT shifter boot, Fabspeed ECU Tune.
F18febe is offline   Reply With Quote
Old 03-13-2016, 09:23 PM   #4
I am my own mechanic....
Timco's Avatar
New clutch here. Has a very audible creek (creak?) when clutch is pushed in when it's warm. It can be felt in the pedal.
'08 VW Touareg T-3 wife's car
Old 03-14-2016, 07:05 AM   #5
flaps10's Avatar
If the sound is coming from behind you it is common, and the fix is to use the 987 clutch lever, pivot ball, etc.
Consult Wayne's 101 book
If it's the pedal assembly then crawl in there with some teflon spray
flaps10 is offline   Reply With Quote
Old 03-14-2016, 07:27 AM   #6
On the slippery slope
JayG's Avatar
If it is from the pedal area, it is likely the clutch booster spring.
I had a squeek for a while from mine and then it stopped when the spring broke.
Replaced the spring (thanks Woody) and all is good
In my case, the squeaking was a sign the spring was breaking.
Its a pretty easy DIY. Do a search here and on rennlist and there are a couple of threads on the spring
2004 996 Targa Tip
Instructor - San Diego region
Old 03-14-2016, 08:36 AM   #7
Porsche9's Avatar
Thanks JayG. Mine definitely sounds like it's in the pedal area. I'll check it out.
Now I have two projects, this and the window regulator (the common issue with the window not dropping when you open the door).
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
