Old 02-20-2016, 03:35 PM   #1
oc-boxster's Avatar
What's your number?
I was just wondering if anyone else Is like me with a dollar figure in mind as far as a major repair that would make you part with your boxster? I personally have a number of 3,000.00. After 3 years my boxster has needed 12,000 in repairs and maintainence because I was dumb and didn't do a PPI. But even after that the next time it needs more than basic maintainence I think I'd rather put the money into a newer Porsche.
oc-boxster is offline   Reply With Quote
Old 02-20-2016, 03:37 PM   #2
oc-boxster's Avatar
My 2002 S now has 122,000 miles and runs and drives well and I consider it dependable. I'm hoping to run it to 200,000 miles and go from there hopefully
Old 02-20-2016, 03:51 PM   #3
My number is 6345789
Old 02-20-2016, 03:58 PM   #4
Retroman1969's Avatar
I'm in the same boat as you basically as far as what I've done and where I am with my 986.
From here: All the sub-$3,000 things it will need I'll do, like brakes, clutch, suspension components, etc, but if the engine blows..... Well that's a sticky question. Do I dump it and drop wad on a newer car? Or drop a used engine in this one and keep going? I'm not sure. Depends on my state of mind at that time I suppose.
Old 02-20-2016, 06:21 PM   #5
What repairs have you had that totalled 12K?
asteroid hyalosis is offline   Reply With Quote
Old 02-20-2016, 07:41 PM   #6
stelan's Avatar
In my case I think that I would keep it regardless of needed.
stelan is offline   Reply With Quote
Old 02-20-2016, 07:48 PM   #7
oc-boxster's Avatar
The 2 major things were clutch/flywheel/ims/rms and a complete suspension refresh then smaller things from wheel bearings, engine mount, water pump, AOS, axle rebuilds, fuel sending unit, new top, brakes, rotors, tires , fluids, labor etc etc
Old 02-20-2016, 07:58 PM   #8
After more than 100 track days, building a Boxster race car, three engines, two transmissions, four clutches, 30+ sets of tires, etc, etc; I am committed to spending whatever it takes to keep the Boxster on the track.
I have a small decal on each side of the Boxster that says: Race. Repair. Repeat.
Old 02-21-2016, 01:57 AM   #9
Rennzenn
j.fro's Avatar
💍I'm committed to the 986. Sooner or later she's going to the Porsche Parade to take on the 914s at autocross. With the right power, I believe the 986, being smaller, will turn out to be a better ax car than the 987, 981, or 718.
Rennzenn
Jfro@rennzenn.com
