Old 01-10-2016, 08:18 AM   #1
flouese's Avatar
Striped maf torxs
Previous owner did me no favors by striping most of the MAF torxs head, I finished the process today while trying to remove the MAF. Searched the forum on how to get those buggars out and had no luck. Anyone w/experience removing them.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 01-10-2016, 08:39 AM   #2
As they are not overly tight, a small easy out should break them loose. Barring that, use a Dremel tool to cut a slot into them and use a screw driver.
Old 01-10-2016, 09:00 AM   #3
flouese's Avatar
Do you need to bust the security post out before you try the easy out or go through it?
99 Boxster base
1966 912 3 gauge
Old 01-10-2016, 09:04 AM   #4
You may need to grind it away to get the easy out to bite.
Old 01-10-2016, 09:09 AM   #5
Might small vice grips do the trick?
2001 Boxster
Old 01-10-2016, 09:58 AM   #6
Yes, that is how I get them out... they are not too tight
Old 01-10-2016, 10:17 AM   #7
That's what I used before getting the right tool to remove them.
Woody
Old 01-10-2016, 11:50 AM   #8
lkchris's Avatar
If you get a paintbrush and paint a stripe on them, they're striped.
If you round out the bolt head, it's stripped.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 01-10-2016, 12:01 PM   #9
steved0x's Avatar
Maybe you could grab the head with a pair of cutters/dykes and remove it, I think.it is just threaded into plastic.
Old 01-10-2016, 01:58 PM   #10
flouese's Avatar
IKCHRIS,
Appreciate the spelling lesson, however, not very helpful in removing the torxs.
99 Boxster base
1966 912 3 gauge
Old 01-10-2016, 05:21 PM   #11
stelan's Avatar
Yea a slot wit a dremmel disk is the way to go
stelan is offline   Reply With Quote
Old 01-10-2016, 06:55 PM   #12
Joe B's Avatar
Spelling does matter sometimes. I honestly read this thread to see why he had stripes on his MAF torx . Sounds like he got some good advice for removing them.
Old 01-10-2016, 10:14 PM   #13
JayG's Avatar
good grief. This is starting to sound like the rennlist 996 forum, and that is not a good thing
