Old 10-12-2015, 07:55 AM   #1
Boxster engine belts?
I'm getting ready to take my 2007 to the mechanic to get some maintenance done, spark plugs, oil change, brakes, air filters, etc.
On my previous car, I used to replace the engine belts every few years, but I can't find any info about the boxster belts. Does the boxster use belts that should be replaced?, if so can anyone recommend a parts vendor?
lurky is offline   Reply With Quote
Old 10-12-2015, 08:20 AM   #2
Every 30k miles is the Porsche recommendation. It's on the list of things you do at the 30k mile services. I grabbed mine from pelican. I just find them easiest to work with and they present all oem parts without the Porsche sticker on it that adds 50 percent markup. One serpentine belt that's pretty easy to replace. Right behind the seats.
Old 10-12-2015, 04:09 PM   #3
Your belt is 8 years old.
Your car only has one belt, the serpentiine belt. The belt is about $25. Your mechanic will spend about a half our removing and replacing the firewall carpet and access panel and 5 minutes replacing the belt.
Old 10-12-2015, 07:01 PM   #4
"can anyone recommend a parts vendor?"
Try Pelican because of good prices ,great service and outstanding diy info.
Here is an article relevant to the project you mention:
Porsche Boxster Spark Plugs and Coils Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Porsche Boxster Drive Belt Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
http://www.pelicanparts.com/catalog/SuperCat/1048/POR_1048_BRKPAD_pg1.htm#item0
http://www.pelicanparts.com/catalog/shopcart/101P/POR_101P_BOX003_pg1.htm
Lots more just Google "Pelican Boxster +your project" or buy Wayne's book - no better diy book for the Boxster exists.
Old 10-15-2015, 08:05 PM   #5
Does anyone know what ball bearings (model/type numbers) are needed to rebuild the serpentine idler pulleys in an '01 Boxster base 2.7 with A/C (US-spec)? Thanks!
Old 10-15-2015, 11:35 PM   #6
Steve Tinker's Avatar
The bearings are 5202-2RS on all 3 pulleys.
2001 MV Agusta F4.
Old 10-17-2015, 09:31 AM   #7
Thank you, Steve!
Old 10-17-2015, 10:02 AM   #8
Is that the same bearing for the pullies on the 3.2?
Old 10-17-2015, 01:40 PM   #9
JayG's Avatar
IIRC, the service interval for the serp belt is 60k miles, not 30 k. They are cheap enough that it certainly would not hurt to replace every 30k if you like. Easy DIY, just takes longer to get to the belt than to actually change it
Old 10-17-2015, 02:51 PM   #10
Yes - they are the bearings I installed on my 3.2 pulleys, though I don't think I would do it again. The pulley surfaces wear as well as the bearings, so next time I will buy new .....
2001 MV Agusta F4.
Old 10-17-2015, 10:15 PM   #11
Pdwight's Avatar
Tag
For reference
