Old 04-14-2006, 02:58 PM   #1
Help! The Key is Struck in the Ignition
I have an 01 and never had problems before but today coming home from work I notice that after stopping for gas that I couldn't get the key out. I can turn off the engine just can't turn it all the way to get it out. I then went home and the key is stuck in the ignition. Strange! The key is not bent or I didn't have problems getting it out before.
Any suggestion?
spgribben007 is offline   Reply With Quote
Old 04-14-2006, 03:16 PM   #2
Any suggestion?
Did you try wiggling the steering wheel while in park?
Todd
2005 Boxster S - Atlas Grey/Black, PASM, Sport Chrono, Bose
2006 Infiniti M35 Sport
2007 Cadillac Escalade (tow vehicle with bling)
'00 Boxster - 2.7l w/FVD ECU tuning, Moton double adjustable suspension, custom stainless headers, lightweight flywheel, dual Magnaflow mufflers, 18" CCR wheels, 911 front brakes in front, Boxster front brakes in rear, full welded cage.
http://www.epiqautosport.com/images/epiqtoddavatar2.jpg
EPIQTodd is offline   Reply With Quote
Old 04-14-2006, 03:32 PM   #3
I tried wiggling the steering in park and I made sure that the steering wasn't turned all the way left or right.
I don't know if it's a electrical or mechanical problem. If it's electrical I'm thinking about disconnecting the battery and reconnecting it to see if it clears the problem but if it mechanical I do not know what to do.
Old 04-15-2006, 07:47 AM   #4
I assume you have a TipS as you mention "...In Park". If so, try putting the Car in Neutral and see if that helps, also, make sure to depress the Brake Pedal and see that you're between steering locks on the steering wheel. Hope this helps...
Happy Motoring!... Jim'99
Old 04-15-2006, 07:56 AM   #5
Brucelee's Avatar
If all else fails, I say a bad ignition switch. I had one that would not give up its key.
Best of luck!
Rich Belloff
Old 04-15-2006, 08:00 AM   #6
Brucelee, if it's a bad ignition switch what are we talking price wise? I'm assuming it's a repair done at the dealer.
