Old 03-29-2015, 02:59 AM   #1
locking lug bolts- how to get them off without proper socket ?
When I purchased my 02 S it did not come with the locking lug nut socket. I have searched everywhere in the car and can't find it. So I'm riding on borrowed time for a flat or needing to remove a wheel. Any way to get these off ? I have already purchased replacement OEM lug bolts ( non-locking ) so I'm not concerned about saving the lockers. But obviously don't want to damage the wheels. I have a impact wrench but I'm wondering what type of socket would you use ? Do tire dealers/shops have a way to get them off ? Or should I go to a Porsche dealership ?
Old 03-29-2015, 03:35 AM   #2
Pdwight's Avatar
Get with Woody or Instanova , Im sure he can fix you up
Old 03-29-2015, 03:46 AM   #3
You mean to get the OEM wheel socket ? I never thought of that do you know if they are that generic ?
Old 03-29-2015, 04:34 AM   #4
still plays with cars...
BoxsterSteve's Avatar
The dealership service department should have a master set of all lug keys for cases like this. Even the local Ford dealer had a complete set when I wanted to buy a spare key many years ago.
Tire shops generally carry removal sockets, but they butcher the lockers.
Crappy situation, best of luck.
Six speed 2000 Boxster S
Old 03-29-2015, 04:36 AM   #5
78F350's Avatar
You can buy a special socket: Emergency Lug Nut Remover
or you can just hammer an old socket onto it. I've had good luck using an old socket, but I forget the size. 13/16"?
Eric the Car Guy has some great videos. Here's his lug nut removal on YouTube:
https://www.youtube.com/watch?v=mJUUyjJqk5A
Get rid of those locking lug bolts before they are a problem.
Old 03-29-2015, 04:38 AM   #6
Do not drill! They will cost you and you will almost always end up with wheel damage. There are other ways to get them off, google is your best friend here. I'm sure other more experienced members will chime in with suggestions too. Something like this could work too:
Locking Lug Nut Remover | eBay
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 03-29-2015, 05:08 AM   #7
Rennzenn
j.fro's Avatar
Find a socket that's just a bit too small for the lock. Use a sledge to drive it on to the lock, then use a breaker bar to loosen it. My 996 had the locks, but the key socket was lost. I was able to pull all four locks using the same socket. Of course, the socket and locks are all toast afterwards, but I didn't want them anyway. I replaced the locks with regular lug bolts.
If it looks like you might hit the wheel with the sledge, put a 4" extension on the socket. Yeah, this is getting ruined, too. The key here is to use tools that are at the end of their lives anyway.
Rennzenn
Jfro@rennzenn.com
Old 03-29-2015, 05:58 AM   #8
BOOTLEG's Avatar
did the hammer small socket thing. worked great. bought 4 used lugs from itsnotanova for $15 and away we go
BOOTLEG is offline   Reply With Quote
Old 03-29-2015, 06:24 AM   #9
RedTele58's Avatar
I did the socket/hammer it on w/ one of mine. There are over 20 different style locks and the dealer will prolly charge you to do it.
Grab some cheap sockets from Harbor Freight and give 'em a good whack! Easy peasy.
Old 03-29-2015, 06:48 AM   #10
Artist, 986S tinkerer
NewArt's Avatar
Most garages can remove these. Just toss them and put on regular bolts.
Old 03-29-2015, 07:01 AM   #11
I have to use a six sided impact socket on half the cars that come in. Like everyone said, get a socket that is just a little too small and hammer it on. Then loosen the bolt off by hand. Once I've broken the bolt loose, I'll take the hammer and tap around the socket until it wiggles it's way off the bolt head. If that doesn't work, I'll take the socket over to the table vice and hammer the bolt out through the hole using a punch. It sounds scary using the socket trick, but it works every time. One time I had a key break because the lug bolt was on so tight. Did the socket trick and it came right off.
Woody
Old 03-29-2015, 07:31 AM   #12
Pdwight's Avatar
Here you go
02 Boxster s rwd Porsche 986 20 Wheel Lug Nut Bolts Key Locking 101 282 | eBay
Old 03-29-2015, 10:50 AM   #13
schnellman's Avatar
Show of Hands
Who here has ever had a wheel stolen from their car? I think everyone should do what most of us have already done. Take off the lug bolts that require a key and see how far you can throw them. Replace with regular bolts.
Old 03-29-2015, 02:29 PM   #14
Pdwight's Avatar
I sort of did that
I replaced mine with regular, until I buggered up two lugs during a bearing change and had to use one of my locking lugs as a replacement...anyone what my key...send me a lug or two and I will send you my key
Old 03-29-2015, 02:58 PM   #15
Sounds like I'll try the hammer a socket on method. Thanks guys.
Old 03-29-2015, 03:10 PM   #16
Buy some replacement lug bolts from the dealer with the car parked out front and they will usually loan you a set of the sockets for the 10 minutes for you to find the right one and remove 4 bolts. Worked for me twice. The sockets seem to disappear into the mechanics tool boxes.
Old 03-29-2015, 09:56 PM   #17
nieuwhzn's Avatar
Tire shops usually have a set of special sockets. You hammer the appropriate socket on the locking lugnut, it cuts itself into the head and you can then just use a breaker bar to remove the nut. All the serious wheel thieves have such a set, so locking lugnuts are useless and just cause you grief when you loose the key. Just replace with normal lugnuts.
nieuwhzn is offline   Reply With Quote
