Old 03-21-2015, 08:52 AM   #1
oc-boxster's Avatar
Front hood latch
So I finally got to experience what I've read about regarding the circle of fun with the front hood and the battery dying. My front hood latch failed right before I went out of town for 2 weeks so I couldn't use my battery maintainer. The battery drained down now it won't start. Off to my mechanic to fix. What did I learn from this? I should have done the tow hook/hood release mod a long time ago.
oc-boxster is offline   Reply With Quote
Old 03-21-2015, 09:08 AM   #2
Not to transport the Boxster to the shop on the underside of the trailer.
clickman is online now   Reply With Quote
Old 03-22-2015, 05:07 AM   #3
Question-how did the failing front latch cause the battery to drain? You suspect the light? I thought the light automatically turns off after a certain amount of time, say 30 mins or an hour. I have seen my car do it so it's true. How old is your battery?
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 03-22-2015, 06:06 AM   #4
oc-boxster's Avatar
My battery is about 2 years old But the car sat without running for 2 weeks. Normally I use a battery maintainer, but without being able to open the lid I couldn't this time. The battery drained down once before while my mechanic had it for a couple weeks, so I'm going to replace the battery along with the latch. Makes me wonder how long you can let a boxster sit without starting without the battery draining all the way down, assuming the battery is fully charged and good.
Old 03-22-2015, 06:56 AM   #5
steved0x's Avatar
I go for weeks sometimes and all is good, the only time mine died was when I left the key in, my battery was mfg June 2011.
Old 03-23-2015, 03:19 AM   #6
Luckyed
Luckyed's Avatar
I run my battery tender through the cigarette lighter. Avoids the issue with the front trunk.
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 03-23-2015, 03:30 AM   #7
My battery is now almost 4 years old and I regularly go for 2 to 3 weeks without starting it, all the while using the car to test and align customers headlights.
Even after that, the battery cranks fast and hard as if it was not affected at all.
You either have a bad battery or a slight parasitic drain. When your mechanic drained the battery, he really should've replaced it because they are never the same after that.
Old 03-23-2015, 05:56 AM   #8
Motorist & Coffee Drinker
78F350's Avatar
Particle, yours is a '99 and his is an '01+. The '01s have more of a drain because of the 'improved' central locking unit (CLU/Immobilizer box/'thingy that gets wet and kills the car'). Still, 2 weeks from full charge to dead sounds like time for a new battery or check on the voltage regulator.
Old 03-23-2015, 06:00 AM   #9
oc-boxster's Avatar
I had a discussion with my mechanic and he is ging to replace the battery at his expense. He agrees the car should have started after just 2 weeks if the battery was good.
Old 03-23-2015, 03:18 PM   #10
oc-boxster's Avatar
New front hood latch is very smooth and quiet. My mechanic charged my battery then did a load test. He said it didn't pass and I should replace it. Took the car to pep boys where I bought the battery and they tested it and said its good so they won't replace on pro-rate. I would like to replace the battery because I no longer trust it. Any suggestions Other that paying full price for a new one?
