Old 12-20-2014, 05:27 PM   #1
Motive Power Bleeder
Hi guys,
I'm about to buy a Motive Power Bleeder. I'm undecided between the standard 0100 kit and the aluminum swivel 0109. Is the swivel worth the extra $25?
hancock1701 is offline   Reply With Quote
Old 12-20-2014, 05:59 PM   #2
I am my own mechanic....
Timco's Avatar
Yes. Very pro and well made.
'08 VW Touareg T-3 wife's car
Old 12-20-2014, 06:09 PM   #3
steved0x's Avatar
The "black label" is worth it.
Old 12-20-2014, 06:46 PM   #4
Originally Posted by hancock1701 View Post
Hi guys,
We have the swivels on all of ours, would not be without it. I also like the quick disconnects that allow you to change the adaptors for various makes without venting the tank.
Old 12-20-2014, 06:53 PM   #5
Great kit.
JFP, Quick question...What pressure do you use when bleeding brakes/clutch?
I stay between 10-15psi but am curious what your shop uses.
dghii is online now   Reply With Quote
Old 12-20-2014, 07:47 PM   #6
Thanks guys, also, many say it's better to use it dry, without brake fluid?
Old 12-20-2014, 09:21 PM   #7
rp17's Avatar
Thanks guys, also,many say it's better to use it dry, without brake fluid?
Good question. I use mine with the fluid in it. If its better to do without, I can skip the clean up drill afterwards.
Old 12-21-2014, 04:36 AM   #8
I have an older model Motive and the first time I used it " wet " the damn hose became dislodged at the tank and sprayed out brake fluid ! I decided right then to use it dry. Been using it like that for years now and no clean up needed, just keep an eye on the fluid level of the master cylinder reservoir. The newer models are probably better than what I have.
Old 12-21-2014, 07:46 AM   #9
Chuck W.'s Avatar
For the past ten years I have used mine "wet". No issues at all and a thorough clean up afterward and all is good.
1995 Porsche C4 Cab
Old 12-21-2014, 08:49 AM   #10
Great kit.
We try and stay between 12-15PSIG, you really do not need more pressure than that.
Old 12-21-2014, 08:50 AM   #11
We use them as they were designed to be used, wet.
Old 12-21-2014, 09:19 AM   #12
It is not. Using the tank dry creates the opportunity to induce air into the system, which then becomes problematic to get out as it goes directly into the ABS/PSM system which would need to be activated (Durametric, PIWIS, PST II) to get it out.
It also eliminates the "one man" advantage of the Motive system, as the reservoir needs to be monitored to make sure it does not run dry.
Old 12-21-2014, 01:48 PM   #13
Black label used wet. Simple, easy, effective. I never thought it could be this easy but it is.
