12-10-2014, 08:13 PM
#1
Just have to give a shout out and Props
I just recieved my lights from Particlewave . I cannot say enough good things about his work......just stellar.
I managed to get two coats of wax on the front before installing the headlights so it should b protected for the winter. I did find one thing I did not like and it has noting to do with PW's work. My drivers side headlight would not light up...sao I found that bracket that holds the receptacle was broken...it must have happened when I hit the two Deer months ago and the shop just plugged the light in by hand. Does this require a new mount or is there a fix for this ??
Thanks PW for your great work...I am truly impressed.....and Fred's projectors are awesome.
Sincerely
Dwight
12-11-2014, 04:46 AM
#2
I am my own mechanic....
There is a clip that holds the plug into that bracket. If the bracket is broke, it's part of the HL mounting assy.
'08 VW Touareg T-3 wife's car
12-11-2014, 05:56 AM
#3
Sadly yes....the bracket is snapped off..so it is the entire mount.....well crap
12-11-2014, 08:21 AM
#4
Contact Oklahoma Foreign. I've bought a few items from them, reasonable and fast shipping.
http://stores.ebay.com/Oklahoma-Foreign?_rdc=1
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
12-11-2014, 08:56 AM
#5
try to JB weld it first...
I had the same wonderful interaction w/ a deer... actually two... in another vehicle. The headlight (xenons as well) mounting tabs broke there too but I was able to JB them to make them work like new again.
Good luck
"Cool Prius!" - Nobody
12-11-2014, 01:33 PM
#6
Thanks Dwight!
Consider it a wedding gift. Best of luck to you both!
12-11-2014, 01:40 PM
#7
You can pull the wheel liner back a little bit and reach in there to plug it in by hand.
12-11-2014, 03:55 PM
#8
+1 on that!
Plug it in and you're good to go!
12-11-2014, 05:32 PM
#9
What is the rubber air tube for???
12-11-2014, 07:36 PM
#10
Yes I would like to know as well
I did just plug them in and they work fine. I got them adjusted tonight and words cannot describe how great they are. They are so much superior to the halogen lights. And a word to Fred, I know I bugged you about a 55 watt unit way over a year ago, glad you talked me out of it...these things are so bright it is unreal. I adjusted them so the cut off is just below a tag on a small SUV (Honda) and below trunk level on a compact car while in low beam. ort I managed to get the two cutoff lines to merge perfectly and on bright the ISS called me and gave me a compliment.
Pictures to follow.....I know I am boring you guys to death....But Particalewave and Fred are a hard pair to beat.
Dwight
12-11-2014, 08:01 PM
#11
Breather Pipe
or so says ********************************************
12-11-2014, 08:36 PM
#12
Yes, that's the headlight vent tube. There are 2 small holes in the bottom of the headlight connector that vent through the tube.
12-11-2014, 09:13 PM
#13
So.....
It just helps keep the inside of the lamphouse dry by negative pressure as you are driving using the venturi effect ?
12-11-2014, 09:20 PM
#14
I'd think more for just expansion and contraction of air. It's passive, so no air actually being forced into it.
I'm glad to hear that you got the plug sorted! Thanks for the compliments, also
12-11-2014, 09:51 PM
#15
and for the Wedding I intend to make a toast to you
The tubing should exhibit negative pressure at highway speeds, not much but it should have a continual drying effort due to the venturi effect....not sure how effective but I'm sure smarter people than I came up with this.
12-11-2014, 10:36 PM
#16
Ah, I see what you're saying. That makes sense.
