03-22-2014, 09:09 AM
front motor mount
Changed the front motormount on the 04 boxster S today at 58K miles. Some cracking of the rubber at the edges, but not a lot. don't know if it was bad enough to notice any difference, it is a tiptronic. At least now I know it is good. Not a real bad job since I have a lift and good supply of tools. Would have been considerably more difficult without the lift. Took about an hour and a half, taking my time and cleaning everything up well.
03-22-2014, 09:57 AM
Two back ones OK then?
1998 986 with ladder racks.
03-23-2014, 05:02 AM
Yes, in nice shape. The tiptronic trans may not put as much strain on mounts as the six speed. I really had not noticed any symptoms of a bad mount, but was just preparing for a cross country rally of about 7K miles and wanted to head off any potential problems. Now a water pump, thermostat and belt, new tires and oil change.
03-23-2014, 10:48 PM
Did you get the whole mount or just the bushing?
03-24-2014, 05:07 AM
I got the whole mount. I have a machine shop that thinks he can press the bushing in/out, but is not sure about getting the alignment of the mount holes just right. Decided not to chance it. I may pick up a bushing and try it with the old mount now that I have one to play with.
03-24-2014, 08:44 PM
A quick question. What are signs of the front motor mount going off?
Cheers
Richard
986 S MY 2004 S Manual Arctic Silver - LN Engineering upgrade, 997 shift kit, speedtech exhaust, Schnell front and mid strut braces.
03-25-2014, 11:17 AM
Cheers
Richard
Generally some vibration, jerking of the gearshift lever when acceleration bumping sound when changing gears, and general loose feeling in the drive train. sometimes hardly any symptoms at all.
05-08-2014, 10:43 AM
Once again I'm scouring thru the posts looking for answers - love this forum
Noticed the other day that I can feel some "shifting" in the gear shift lever when accelerating and sometimes when letting off the accelerator. Not bad enough to call it a "jerking" of the gear shifter, and I really almost need to be intentionally "less smooth" with the accelerator to get it to cause the gear shifter to move.
So - how much "shifting / jerking" is normal and when do we start looking at the front motor mount (or transmission mounts?).
05-08-2014, 11:02 AM
Multi-Boxer Driver
I notice this in mine at times as well. I generally only feel it if I have my hand on the shifter (I don't rest it there). I have over 100k miles on mine, how many do you have on yours (what year)?
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
05-08-2014, 11:09 AM
98' with 88K miles. Same here - only notice with my hand on the shifter - didn't think to visually observe the shifter for movement.
05-08-2014, 11:19 AM
I changed mine a couple weeks back, did not notice really anything that pointed to the motor mount but was under the car doing some preventive work and thought I might as well do it as I had just over 65k.
Let me say one thing I can now have a nice conversation in the car, and do notice shifting seems better but as they wear over time I guess I just got use to the extra noise vibration.
After looking at it I am so glad I replaced when I did!
05-08-2014, 12:57 PM
I think someone smart like Pedro wrote that the front motor mount from the factory craps out at about 40-50k miles and that's all one should expect from it.
Now upgrading to something that will last longer will also cause more vibration... Porsche engineers their parts for performance AND comfort.
I've replaced mounts on three different Boxsters over the last few years. Shifting improves, idle is smoother and no harmonic vibration at ~3K rpm are the main things that get fixed.
I did swap just a bushing in the mount one time and it wasn't very hard to do. The bushing as $39. Prior to removing the old bushing, I marked it and its position in the mount. I then sat the new bushing on top of the old, alingned the holes and marked it as well.
I put my motor mount in a vice and used a hack saw to break up the old mount and pull it out. It was quite easy to do by hand. I then took my new (Frozen) bushing, alinged the holes and pressed it in using the vice. It when right in without any drama.
05-08-2014, 06:43 PM
1999 base
Do you have the bushing part number by any chance?
05-09-2014, 12:49 PM
Got mine at ********************************_az
05-09-2014, 12:51 PM
sorry. PM me and I'll tell you where I got my bushing.
05-09-2014, 02:44 PM
1999 base
thanks guys.
