03-09-2014, 01:44 PM
I am my own mechanic....
Repair notes...
Squeaky rear brakes. Pads look almost new in thickness. Never squeaked until new rear rotors.
Finally pulled them. I could see my reflection in two and all 4 had grooves and scratches the shape of the rotor.
Used 120 grit on my palm sander and kept the pad perfectly flat on the sander and took them down until perfect matte finish.
Silent.
'08 VW Touareg T-3 wife's car
03-09-2014, 02:04 PM
Good info. Just changed pads and rotors on my kids RSX. He's complaining about squeaking. Will give this a try.
Glen
03-10-2014, 06:12 AM
You do realize that there is a break-in procedure for new rotors and/or pads, right? Each manufacturer is slightly different, but they all have them.
For instance, Hawk recommends:
"After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph. Do not allow the vehicle to come to a complete stop.When completed with this process, park the vehicle and allow the brakes to cool completely before driving on them again. Do not engage the parking brake until after this cooling process is compete"
2000 986 S - "The Black Widow"
03-10-2014, 11:33 AM
I followed something similar to this. My issue was new rear rotors with existing but near new pads. The rotors had some painted surface. This has totally reset the pads.
03-10-2014, 12:14 PM
Your solution appeared to work which is good. But I was about to mention the same procedure as above. What was the similar procedure that you did that didn't work? Just curious
03-12-2014, 04:38 AM
I did pads and front rotors a year and a half ago. I think there was a slip of paper with the pads, TRW.
The rear rotors were about a year later. Paper that came with those says new pads must be used but my pads were still very new in thickness. No break in instructions. It was used pads on new rotors that made it squeak bad. Every stop. Resurface has made them silent.
03-12-2014, 06:41 AM
A Team Porsche Race driver from the 70's told me that they would slip sandpaper between the discs and rotor and do a lap to "resurface" the rotors if they were giving less than optimal performance.
