Old 02-13-2014, 04:32 PM   #1
There Is No Substitute.
rick3000's Avatar
What is your volume setting?
Hi Everyone,
Yesterday, I finally installed a 6x40W 996 amplifier to power my rear speakers, and replace my 4x40W amp. The output should be the same, but I now have to turn the volume on the Becker CDR220 radio up more than before to achieve the same volume.
I used to set it anywhere between 8-14, now I am in the 20-26 range. Could there be an issue with the amp, or a setting I need to adjust? I like the lower numbers because the speakers are less likely to making that popping sound at ignition/shutdown and it minimizes any ground loop buzzing.
Also, curious what volume level everyone else is normally around?
Best,
-Rick
Old 02-13-2014, 05:08 PM   #2
Does the amp have any on board gain controls? My car didn't come with any stock stereo equipment, so I can't comment on the volume level.
Old 02-13-2014, 05:52 PM   #3
oc-boxster's Avatar
7-12 on my factory Bose stereo
oc-boxster is offline   Reply With Quote
Old 02-15-2014, 07:13 PM   #4
11...
98 Arena Red 986
Old 02-16-2014, 02:17 PM   #5
Auf los!'s Avatar
Stroked...
That is one funny picture! Is it some kind of audiophile's inside-joke?
2001 Boxster S 6-speed, 2013 Boxster S PDK
Auf los! is offline   Reply With Quote
Old 02-16-2014, 03:07 PM   #6
Damn Yankee
TeamOxford's Avatar
I'm definitely not an expert on the subject, but when I had this problem with a home audio system, it was the result of an impedance mismatch. The impedance of my speakers did not match that of my amp, and I needed excessive power to achieve a reasonable volume level.
Just a thought; as I stated, I'm no expert.
My optimum volume level on a CDR220 with a stock system is between 10-15.
TO
Old 02-16-2014, 03:09 PM   #7
Damn Yankee
TeamOxford's Avatar
It is if you're into Spinal Tap.
TO
Old 02-16-2014, 06:17 PM   #8
rick3000's Avatar
TO
TO, you nailed it. My iPod connector has a Hi/Lo filter switch, and at some point during the amplifier installation it got switched off. I didn't even now it had a switch until I pulled everything out again to see what the problem could be. I taped the switch to make sure it doesn't happen again.
Thanks for all the replies!
Old 02-17-2014, 07:48 PM   #9
TO
"Why don't you just make ten louder and make ten be the top number and make that a little louder?"
All together now .... "These go to eleven."
dbear61 is offline   Reply With Quote
Old 02-17-2014, 07:51 PM   #10
Damn Yankee
TeamOxford's Avatar
Is that you Nigel?
Derek
Old 02-17-2014, 08:50 PM   #11
I usually set mine to 6,800rpm.
