Old 02-16-2014, 03:07 PM   #6
TeamOxford
Damn Yankee
TeamOxford's Avatar
Yesterday, I finally installed a 6x40W 996 amplifier to power my rear speakers, and replace my 4x40W amp. The output should be the same, but I now have to turn the volume on the Becker CDR220 radio up more than before to achieve the same volume.
I used to set it anywhere between 8-14, now I am in the 20-26 range. Could there be an issue with the amp, or a setting I need to adjust? I like the lower numbers because the speakers are less likely to making that popping sound at ignition/shutdown and it minimizes any ground loop buzzing.
Also, curious what volume level everyone else is normally around?
I'm definitely not an expert on the subject, but when I had this problem with a home audio system, it was the result of an impedance mismatch. The impedance of my speakers did not match that of my amp, and I needed excessive power to achieve a reasonable volume level.
Just a thought; as I stated, I'm no expert.
My optimum volume level on a CDR220 with a stock system is between 10-15.
TO
