		|  10-09-2013, 10:21 AM | #1 |
	| I am my own mechanic....
				Need help / advise! How are you getting your crank nut off??
			Tried many ways to immobilize. It's super tight. Sigh.
Thoughts?
				__________________'04 Boxster S 50 Jahre 550 Spyder Anniversary Special Edition, 851 of 1953, 6-sp, IMS/RMS, GT Metallic silver, cocoa brown leather SOLD to member Broken Linkage.
 '08 VW Touareg T-3 wife's car
		|  10-09-2013, 10:23 AM | #2 |
			And won't I need a shorter belt?
		|  10-09-2013, 10:27 AM | #3 |
	| Registered User
			in your pulley there is a hole that allows you to pin the pulley in place into a boss locate behind it. use an appropriately sized Allen key to do the task. you may not need a shorter belt; depends on how much smaller your new pulley is.
		|  10-09-2013, 10:34 AM | #4 |
			Is this boss dead bottom?
		|  10-09-2013, 10:44 AM | #5 |
	| Registered User
			iirc correctly it is at around 10 o'clock.
		|  10-09-2013, 11:01 AM | #6 |
			Thanks. That did it, but now the UD pulley will not clear that very dog.
 Damn!!!
		|  10-09-2013, 11:14 AM | #7 |
	| Registered User
					Originally Posted by Timco  Thanks. That did it, but now the UD pulley will not clear that very dog.
 Damn!!!
That is because to install an under drive pulley, you need to machine some of that boss off.
				__________________“Anything really new is invented only in one’s youth.  Later, one becomes more experienced, more famous – and more stupid.”  - Albert Einstein
		|  10-09-2013, 11:19 AM | #8 |
					Originally Posted by JFP in PA  That is because to install an under drive pulley, you need to machine some of that boss off. |
Just searched and found that. Thanks.
Now I do need a shorter belt. Off to parts.
		|  10-10-2013, 02:26 AM | #9 |
	| Registered User
			JFP, any downside to installing the under drive pulley?
		|  10-10-2013, 02:58 AM | #10 |
	| Need For Speed
			People should post pictures of these things.
		|  10-10-2013, 06:32 AM | #11 |
		|  10-10-2013, 06:33 AM | #12 |
			It's a fraction of the size of the orig and needed a shorter belt.
 WAY more power low end!!!! Zero other felt differences so far.
		|  10-13-2013, 03:55 PM | #13 |
	| Registered User
			Is the nut normal thread or reverse?
				__________________'99 Boxster Artic Silver/Red
 '14 Subaru Outback
 '06 EG Classic
 '05 Sportster
		|  10-13-2013, 06:07 PM | #14 |
					Originally Posted by Brockmeister  Is the nut normal thread or reverse? |
RHT, or Right Hand Thread. (Normal)
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 04:13 AM.
