Old 09-09-2013, 08:49 AM   #1
Exclamation A Boxster doesn't float!
Yesterday a went with my wife for dinner and a storm break up. The interior light of the car and the emergency light start to blink. We arrive to our house safe. I decided to disconnect the battery. Next day I reconnect the the battery and central locking switch was blinking. The remote control, windows, trunk switch doesn't work. The car start, the radio, lights, computer, horn works. I decide to check the anti theft control module under my seat and it was wet. I disconnect the battery, dry every thing but is the rug is wet so I decide to left the car alone until is dry. I will appreciate any recommendations or tips, regards. :ah:
Boxster Base 2002.
Laredo is offline   Reply With Quote
Old 09-09-2013, 09:09 AM   #2
The central locking and immobilizer computer under the driver's seat is probably wet, and will need to be removed and dried out.
Old 09-09-2013, 09:15 AM   #3
Just phoning it in JFP?
Laredo: you are on the right track. It wouldn't hurt to open it up and flush with rubbing alcohol, also. Check all connectors for corrosion before re-installing.
Your water issue needs to be resolved, too. Check and clear your drains
Old 09-09-2013, 09:33 AM   #4
Thank you for the advice. I already remove the left seat and use a dryer. Particlewave do you mean to open the control module? Is it possible? Anybody has experience in this particular problem to adventure a prognosis in the module?
Old 09-09-2013, 09:47 AM   #5
Only for questions that have been asked and answer several times previously.......
Search is your friend.
Old 09-09-2013, 09:48 AM   #6
It's a throw of the dice as to whether or not the unit still works. Yes, you absolutely need to open it up and flush with rubbing alcohol. I would also use a soft bristle brush to carefully and gently scrub the board.
It's not the water that does the long term damage, but the mineral deposits that water leaves behind. Cleaning with rubbing alcohol eliminates the deposits. There are several members here who have had the same problem and using the above method is the best route.
Old 09-09-2013, 11:30 AM   #7
I have the module in my hands, but I can't open it. Do you have a procedure to accomplish this?
Old 09-09-2013, 04:34 PM   #8
Ok I opened the module and flush with alcohol and cleaned. I notice a discoloration in the PCB. Anybody knows if its normal?
Old 09-09-2013, 06:57 PM   #9
Ok I reinstalled The module And The window, the central locking switch and the remote doesn't work everything else is fine. If anybody has any recommendations I would appreciate it. I will start looking for new module. Regards Enrique. PS here we have very crafty people it is possible to repair the PCB?
Old 10-07-2013, 04:48 PM   #10
DJ Richard's Avatar
No, a Boxster does NOT float. Story HERE
Richard
2002 Boxster S, Guards Red, 6 Speed
DJ Richard is offline   Reply With Quote
Old 10-07-2013, 06:47 PM   #11
BYprodriver's Avatar
Ba,day! Mate? :dance:
Old 10-07-2013, 09:23 PM   #12
I am sorry mine didn't, but it can run and sometimes fly!
:dance:
Old 10-08-2013, 07:45 AM   #13
"The insured 2000 Porsche Boxster convertible worth about $50,000 and now......"
I can let my 2000 Boxster go for $40,000 if it will help the guy! LOL!!!! :^)
wkb28791 is offline   Reply With Quote
