07-28-2013, 08:06 AM
#21
Here's a question... Got a set of twists on a steal of a price. They just been powdercoated fronts have part # 996 362 136 01 18x8 Et 50. Backs are 996 362 140 02 18x10 Et 47. Will they fit?
They are gorgeous.
07-28-2013, 08:19 AM
#22
Originally Posted by Dgnarvs
Going for the Boxster fitment also means there is no added aggressiveness to the look! Hmmm...
How so...?
07-28-2013, 04:11 PM
#23
2001 Boxster S
Originally Posted by ekam
How so...?
Aggressiveness in this case relates to how much the wheels extend out. The boxster fitment does not require spacers and the width is narrower.
2001 Boxster S
Arctic Silver
'Brenda' aka Money Trap aka 100% Fun!
07-28-2013, 04:19 PM
#24
They don't require spacers, but you can still get spacers if you want them to extend out?
You're only going to put 265 rears regardless of wheel width? Unless you want 285 which is what the 996 carrera wheels are designed for.
07-28-2013, 04:44 PM
#25
2001 Boxster S
You're only going to put 265 rears regardless of wheel width? Unless you want 285 which is what the 996 carrera wheels are designed for.[/QUOTE]
True. But it's also because the 996 wheels were being offered at a good price and I wanted to know if they would fit...and also because I still haven't found boxster ones.
2001 Boxster S
Arctic Silver
07-28-2013, 11:15 PM
#26
@mump
Here is the guidance:
Fronts : 8 to 8.5 inches wide with offsets ranging from +35 to +45 depending on how aggressive you want to go.
Rears: 9 to 10 inches wide with offsets ranging from +35 to +45 depending on how aggressive you want to go.
So to answer the question, yes they will fit but you will need to space accordingly to achieve correct fit and the dersired stance.
Don't care......was made to care! (my Mum)
07-29-2013, 03:20 AM
#27
thanks. so i should probablt not switch over my tires until spacers?
I can worry about stances later, just don't want any rub or such.
07-29-2013, 08:13 AM
#28
I use 20mm rear spacers w/Carrera lights and they sit fairly flush. 285 max width tires.
A word of warning - I think my wheel bearing life took a nosedive after installing spacers.
98 Arena Red 986
07-29-2013, 10:15 AM
#29
I heard spacers do extend the weight of the wheel further away from the hub, placing more strain on the bearings.
I have to run 5mm spacers all the way around on my car due to my dropped stance and coilovers...
07-29-2013, 10:13 PM
#30
Originally Posted by mump
thanks. so i should probably not switch over my tires until spacers?
Anyone? I have an apptment tomorrow take my 265's off my old rims and put them on my "new" rims tomorrow, and I would like to drive away from the store....
07-30-2013, 03:20 AM
#31
This is something that nobody talks about... but yes anything more than 5mm will progressively wear out your bearings. Hence why I prefer on getting the Boxster offset wheels to begin with.
07-30-2013, 06:46 AM
#32
2001 Boxster S
Ah...now that's interesting. I knew there was a reason why I felt iffy about spacers!
2001 Boxster S
Arctic Silver
07-30-2013, 10:05 AM
#33
Sorry Ekam, but that's not true. If the Net offset is the same, your wheel bearings don't know if you have a spacer or not (assuming they are quality, and hubcentric). A +25mm offset wheel is effectively the same as a +35mm with a 10mm spacer. Anything that still fits in the stock wheelwells will NOT be enough to affect the wheel bearings.
Reason: My math was off!
07-30-2013, 01:55 PM
#34
Originally Posted by stephen wilson
Sorry Ekam, but that's not true. If the Net offset is the same, your wheel bearings don't know if you have a spacer or not (assuming they are quality, and hubcentric). A 45mm offset wheel is effectively the same as a 35mm+10mm spacer. Anything that still fits in the stock wheelwells will NOT be enough to affect the wheel bearings.
This isn't true either. A 35mm offset with a 10mm spacer equals 25mm offset
07-31-2013, 03:03 AM
#35
Sorry, I should have checked my example better! That's what I get for posting in a hurry. But the point remains the same.
07-31-2013, 03:43 AM
#36
No problem, it's easy to get confused and think a spacer is part of the hub instead of the wheel
07-31-2013, 04:19 AM
#37
And nevermind if you have spacers you have to get extended lug bolts... Porsche only makes +5mm lug bolts. Any longer you're on your own.
07-31-2013, 11:17 AM
#38
07-31-2013, 11:21 AM
#39
Suncoast Porsche lists some of the spacers that Porsche makes including 17mm or more. My Porsche 20 MM spacers utilize the stock wheel nuts and a set of ALUMINUM nuts!
07-31-2013, 11:25 AM
#40
Mump
wow, nice paint! You're motivating me to wet sand and polish mine.
