Old 04-28-2013, 08:05 AM   #1
2nd bad AOS? Continued thread from yesterday...
So I had the 1126 code... thought it might be a vac leak (MAF and 02 are other culprits).
After taking a closer look I found that I had quite a bit of oil in my intake manifold. The photo shows it... (I wiped it off before the photo too)... it looked like it has been dripping a bit too and pooling on the engine right below where the AOS connects to the manifold.
I just replaced my AOS two years ago... can that part actually be bad already? I mean, two years and about 12k miles on the AOS?
Or is bit of oil normal in there and I'm barking up the wrong tree?
The car has had a rough idol and starting problems...
By the way I did have a bad battery too So that problem is fixed!
bmx672 is offline   Reply With Quote
