03-08-2013, 07:28 AM
Loud Raddle noise on Start up...
Hello everyone,
I have a 1998 Boxster 2.5 and the ignition switch would get stuck like most do. This was one of the issues when I purchased the vehicle about 3 years ago. I replaced the ignition switch, therefore, the key no longer gets stuck in that position.
Only sometimes when the car is turned on, there is a loud grinding/raddle noise for about 2-3 seconds and then goes away. I have tried to see where it is coming and I believe its from the starter. As I mentioned before, it does not happen all the time.
What do you guys think it is, and how can I overcome it because it is annoying.
Thanx in advance for your help
Riz
03-08-2013, 08:05 AM
Mobile Porsche Surgeon
Welcome to the world of Boxster, they all do this it is all related to the poorly designed over head cam chains.
Mike's Specialty Porsche Service
Mobile Mechanic Specializing in Porsche and Select Automobiles
http://www.mikesspecialtyautomotiveservice.com/index.html
Early 1996 / 97 Boxster, 130 k, De snorkeled, IMS, Top Speed Headers.
03-08-2013, 08:11 AM
Some people have found that switching to Castrol Edge 5w40 has helped if they were previously using Mobil1 0w40.
'99 black 986
03-08-2013, 09:22 AM
Originally Posted by OneOfaKind
Hello everyone,
Riz
That is the sound of your valve-train clattering briefly before the chain tensioners and valve lifters build pressure.
Some say that heavier oil will quiet them down. If quiet is the goal then they can have it. IMO, 0W is what is best for this, and just about any street engine. the difference in flow between 0W-30 and 5W-30 synthetic at cold start-up is significant. The difference at operating temp is nil...
03-08-2013, 12:16 PM
I've chased the start up clatter since I got my car a couple of years ago. Changed the 2 lower tensioners and tried all kinds of oil from 0-40 to 20-50 with no significant change. The only thing that reduced, but has not eliminated the rattle has been changing to Red Line 5-40.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
03-08-2013, 01:33 PM
Picking up on your thought that the noise was starter related, I can think of two possibilities. One, the ignition switch is starting to fail again. Two, and perhaps more likely, the throwout bearing on the starter is not allowing the starter to disengage quickly enough.
When it happens, are the conditions similar. For example, is it a cold start on a cold day?
03-08-2013, 02:25 PM
Thanks so much for sharing your thoughts but I have been using 0-40 Oil ever since owning the vehicle. Pretty sure the rattle is not from the oil used but from the starter.
Even after changing the ignition switch, the rattle was still there only on some start-ups.
Whether its cold or hot, the rattle seems to happen because something like the starter does not disengage as thom4782 mentioned.
I think I will have to look at the Starter. LOL
Thanks for the Quick responses guys.
03-08-2013, 02:55 PM
Can you record it at start up and post it?
03-10-2013, 08:45 PM
Interested on feedback too as I may have the same issue.
Here is a recording:
Boxster startup noise - YouTube
2000 Boxster S
03-10-2013, 09:39 PM
I am my own mechanic....
I was getting an intermittent start up squelch. It was the starter. New starter turns over twice as fast!!
Bendix spring. Starter does not pull back in on its own.
'08 VW Touareg T-3 wife's car
03-10-2013, 11:53 PM
Originally Posted by com3dorm3
That's definitely the starter not disengaging fast enough.
03-11-2013, 06:05 AM
recycledsixtie
I have the same sound on after starting my 2001 Boxster base. I assumed that it was the cold weather affecting the starter. However it could be a permanent noise.
Is replacing the bendix starter spring an easy fix?
03-11-2013, 07:12 AM
Mine does the same thing, and I like you have a 1998 2.5. Mine always does it while cold, but never once the engine is warm. The stealership and my go to mechanic have both told me it is a starter bendix issue...or something like that related to the starter. They both told me that Boxster starters almost never fail, but most will get this annoyance with time. Since you have a 1998 2.5, the greater Boxster ever produced, I would not worry too much about it.
1998 986 with ladder racks.
03-11-2013, 07:25 AM
Are the effects of this isolated to the starter or is it impacting other things like the flywheel teeth?
2000 Boxster S
03-11-2013, 07:51 AM
Good question, but the dealership guy did not tell me I needed to fix it, and my other mechanic who does all the work on the car said it was nothing to worry about. Both could have told me replace and I would have, so maybe it IS ok to leave it alone...
03-11-2013, 10:19 AM
This will cause wear on both the starter and flywheel teeth eventually.
If you can source a spring, starters are easy to rebuild. I would fix it...if nothing else, to save yourself the embarrassment of the loud noise
03-11-2013, 10:34 AM
Agree. It should be easy, though not as easy as finding the slope of the line given the equation -7x+3y-11=0
2000 Boxster S
03-11-2013, 10:53 AM
Ahhh...+2.333
Is the sound while cranking the engine on the starter exclusively?
986 00S
03-11-2013, 11:01 AM
Reverse the sign of x, divide by y... 7/3, 2 1/3, 2.3, etc.
Heck, even if you can't find the spring, pull the old one out and stretch it some to give it more spring. Not a permanent fix, but better than nothing.
03-11-2013, 11:06 AM
Originally Posted by jaykay
Ahhh...+2.333
Ah, good that you remembered to put "+". I've had points deducted for not including it, go figure
The sounds seems to be from one source only, but I've been wrong before.
2000 Boxster S
