Old 03-08-2013, 02:25 PM   #1
Thanks so much for sharing your thoughts but I have been using 0-40 Oil ever since owning the vehicle. Pretty sure the rattle is not from the oil used but from the starter.
Even after changing the ignition switch, the rattle was still there only on some start-ups.
Whether its cold or hot, the rattle seems to happen because something like the starter does not disengage as thom4782 mentioned.
I think I will have to look at the Starter. LOL
Thanks for the Quick responses guys.
OneOfaKind is offline   Reply With Quote
Old 03-08-2013, 02:55 PM   #2
Mobile Porsche Surgeon
kashmir's Avatar
Can you record it at start up and post it?
Mike's Specialty Porsche Service
Mobile Mechanic Specializing in Porsche and Select Automobiles
http://www.mikesspecialtyautomotiveservice.com/index.html
Early 1996 / 97 Boxster, 130 k, De snorkeled, IMS, Top Speed Headers.
kashmir is offline   Reply With Quote
Old 03-10-2013, 08:45 PM   #3
com3dorm3's Avatar
Interested on feedback too as I may have the same issue.
Here is a recording:
Boxster startup noise - YouTube
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 03-10-2013, 11:53 PM   #4
That's definitely the starter not disengaging fast enough.
Old 03-11-2013, 06:05 AM   #5
recycledsixtie
recycledsixtie's Avatar
I have the same sound on after starting my 2001 Boxster base. I assumed that it was the cold weather affecting the starter. However it could be a permanent noise.
Is replacing the bendix starter spring an easy fix?
Old 03-11-2013, 07:25 AM   #6
com3dorm3's Avatar
Are the effects of this isolated to the starter or is it impacting other things like the flywheel teeth?
2000 Boxster S
Old 03-11-2013, 07:51 AM   #7
Good question, but the dealership guy did not tell me I needed to fix it, and my other mechanic who does all the work on the car said it was nothing to worry about. Both could have told me replace and I would have, so maybe it IS ok to leave it alone...
1998 986 with ladder racks.
paintboy is offline   Reply With Quote
