02-25-2013, 06:44 AM
What OBD2 cable works with Durametric?
Hello, I want to buy a OBD2 cable to read and erase errors from my 986.
What cable do you recommend me to buy? I was looking for in ebay but there is a lot and I don't know whats works correctly with DURAMETRIC software.
02-25-2013, 07:06 AM
Only the Durametric cable will work.
02-25-2013, 07:52 AM
I actually prefer this 90% of the time.
Actron CP9125 PocketScan Code Reader : Amazon.com : Automotive
Durametric can be useful but it also has some significant software errors that can lead you down the wrong path.
02-25-2013, 10:31 AM
Originally Posted by Nimbus117
I know this is a long shot but can you use this device on a 986 to change from Fehrenheit to Celcius or vice versa?
02-25-2013, 12:07 PM
Do you have the stalk for the OBC or just the setting enabled? There are steps to change using the stalk, but without the stalk I don't know if the software can change it.
02-25-2013, 01:56 PM
Have you tried this?
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
If not then this cable wont do it, need a specialist or dealer with a PST2.
02-25-2013, 02:03 PM
I have tried that a few times and hasn't worked :ah:. Thanks for your help.
02-25-2013, 02:12 PM
I want read codes an erase it. I bought 2 years ago a usb cable that works correctly with durametric, but now doesn't work and need to buy another.
I don't want to waste the money in cables that doesn't work or only read codes, so this is the question what cables do you have.
02-25-2013, 02:17 PM
Didn't work when I tried it either.
As Steve mentioned, if you dont have it already you could get the stalk and retrofit OBC. I did this and is a great upgrade, lots of settings you can change then. Added cruise at the same time.
02-25-2013, 02:56 PM
Do you know where I can get a copy of the software? I actually have a cable that I used for programming my BMW so I just need a link to the software to be up and running. I am going to try and contact the seller also, but didn't know if you had a source.
'01 Boxster S - Silver/Gray
'58 356A Cab - Fjord Green/tan
02-25-2013, 04:01 PM
where can I get the stalk and retrofit OBC? can I erase fault codes too?
02-26-2013, 07:58 AM
I got the bluetooth ELM 327 for about $15 and free Torx cell phone app. Works like a charm.
02-26-2013, 08:14 AM
Download Durametric
12-10-2014, 11:29 PM
Are they work the same?
Is your elm327 device work the same as the Durametric cable
12-11-2014, 03:30 AM
Not even remotely close..................
