Old 02-03-2013, 11:29 PM   #1
Just bought 2000 boxster s
Just bought this baby for the summer with 78,000miles.
the paint was so nasty and I tought I will have to paint the car. BUT after 5 hours of work and 2 layers of polish and 2 layers of wax the paint looks like new
Have some issues to fix:
1. There is a noise from the rear right when passing on bumps. any ideas?
2. When moving from 2 to 3 gear i feal a little bang (tiptronic), could it be the engine mount?
3. I see an oil leak. I need to clean the engine to see where it comes from. any known places for boxsters?
4. speakers - it seems that one of the owners before did a stupid job and chancheled the front speakers. put only tweeters. now I need to set a new 4" speakers but don't have the old speakers to use them as a base. any idea how to do it? or I must buy used speakers from ebay?
5. Hard start - When I'm starting the car COLD it start after 3 second starter spinning. not fast but ok. when the car is HOT (and sitting above 5-10 minutes) it starts after some starter spinning and on the second try with a little press on the gas pedal.
What can it be?
Yaron
Yaron
Thanks guys
1982 Black 911sc coupe
2000 Boxster S
2007 Harley Davidson Night Train (very customized)
1971 conv' beetle, 2332cc (sold )
ybn533 is offline   Reply With Quote
Old 02-04-2013, 06:53 AM   #2
ChrisZang's Avatar
Shalom,
Really hard to do a remote diagnose, but most of your issues have been discussed on this board.
Do a search.
Look for RMS leak, dash speaker, noise in the rear could with be a worn shock, a bad bushing or a broken sway bar link
Good luck
Old 02-04-2013, 09:26 AM   #3
1999 base
Meir's Avatar
Hello Yaron, and welcome to the forum.
did you buy the car from Eli by any chance?
Old 02-04-2013, 10:35 AM   #4
Thanks Chris
Hi Meir,
No, bought it from someone else.
2000 Boxster S
Old 02-04-2013, 11:03 AM   #5
1999 base
Meir's Avatar
Originally Posted by ybn533 View Post
Thanks Chris
Hi Meir,
so once again, congratulation and welcome.
the reason i asked, is because he has the same car, and had issue with a control arm.
i'm sure you will find this forum very helpful, but with suspension noises, it is very hard to point to the problem. as Chris mentioned (nice Hebrew dude) it could be any part of the suspension.
have someone inspect it, and he will be able to tell you which parts are worn.
and yes, any mechanic can do that, don't let them give you the regular "it a Prsche, 10K shekel for a fix" BS.
about the oil leak, two most common issues are the RMS, and the plug tubes.
you can read all about it in this book:
Pelican Parts.com - 101 Projects for Your Porsche Boxster
or in this set of articles:
Pelican Parts - Porsche Boxster 986 / 987 and Carrera 996 / 987 Technical Articles
Old 02-04-2013, 05:14 PM   #6
Autobahn Glanz
WhipE350's Avatar
ybn - Looks nice. You'll get good advice here.
Meir - I sent Eli my control arms, haven't heard back if they helped...funny I wondered the same thing
Old 02-04-2013, 07:58 PM   #7
ChrisZang's Avatar
I think I have pair of front speakers somewhere in my garage, you can have them for free (need to find them first) but I guess shipping to IL will be astronomical ...
Old 02-04-2013, 11:36 PM   #8
Hi Chris,
I have a warehouse in NJ btw.
I just bought this kit to fit speaker in the dash:
someone took out the speakers from the dash.
I will buy new 4" speakers for the dash and 5.25" for the doors. any recommendations?
Thanks guys
Yaron
2000 Boxster S
Old 02-05-2013, 05:55 AM   #9
jcb986's Avatar
Check control arm, also the shock, even the bottom body panel which is made of plastic could be bumping, it's just screwed in.
Very well could be the front motor mount, also check the axles for lose play.
Spark plug tubes, cam plugs, AOS, axle seal at the transmission...just had my done due to a leak.
Check with Porsche and see what they used in the past.
May suggestion is to clean the throttle body real good. But my real thoughts are MAF or fuel pump or the cam sensor and you can clean the cam sensor.
Good luck...I also have a 2000S with TIP, Love It.
Old Hippie Young Heart
Old 02-05-2013, 06:03 AM   #10
Thanks fro the good advises
2000 Boxster S
Old 10-15-2013, 05:25 AM   #11
Hi every one,
Fixed all the problem, left only with the hard start.
1- the cover in the back cabin was making the noise.
2- motor mount was dead
3- spark plug tubes
4- put new speakers
5- Hot start problem.
1-4 fixed alone diy at home.
I talked with the Porsche garage and they want a lot of money for the diagnostics, not talking about parts....
So, I think maybe it's better and will cost me less if I'll change the must common parts that involved with this problem. Maybe it sound stupid but paying 500$ for diagnostics sound more stupid to me. I already bought a new fuel pump. So, crank sensor will be next? what more to eliminate the problem?
Thanks for the advice.
Yaron
2000 Boxster S
Old 10-15-2013, 05:53 AM   #12
heliguy's Avatar
Nice car, but I love the Yak and the pattern plane hanging on your wall.
Old 10-15-2013, 06:51 AM   #13
By your name I understand your hobby too
Btw I have a few more planes....
2000 Boxster S
Old 10-15-2013, 07:27 AM   #14
Hi every one,
Yaron
Which cover? Can you be more specific?
seventythree is offline   Reply With Quote
Old 10-15-2013, 07:31 AM   #15
in the cabin there is a plastic cover under the carpet that covers the the jack there. when you hit a bump on the road it makes noise.
2000 Boxster S
Old 10-15-2013, 07:35 AM   #16
Perfectlap's Avatar
what does it cost you to fill up the gas tank in Israel?
Old 10-15-2013, 07:48 AM   #17
11$ for a gallon
Btw, I see you are from NJ. I have warehouse at Hillside, NJ
2000 Boxster S
Old 10-15-2013, 11:15 PM   #18
Which cabin, what cover, what jack?
Isn't the jack in the front trunk inside the spare wheel?
Are we talking about a Boxster here?
Old 10-15-2013, 11:28 PM   #19
for 5) not trying to state the obvious here ... but maybe your battery is weak/old?
Hi every one,
3- spark plug tubes
4- put new speakers
Yaron
BTfd2e93 is offline   Reply With Quote
