Old 06-03-2015, 08:29 AM   #101
Thumper's Avatar
That's pretty much the going rate for the oil pressure sensor.
Thumper is offline   Reply With Quote
Old 06-04-2015, 08:03 AM   #102
Chuck W.'s Avatar
Originally Posted by KRAM36 View Post
Where did you guys get your oil pressure sensor from? So far $68.85 shipped is the cheapest I have found one.
I purchased mine from Sunset Porsche. They are at $61.25 plus shipping so you are well within the ballpark. Don't forget to order a wire with the connector that plugs into the new cluster for the oil pressure sensor. It is an Audi part but Sunset can include it in your order if you buy from them. The part number is 000 979 010 FA.
PRESSURE SENSOR | Genuine Porsche | 996-606-203-02
1995 Porsche C4 Cab
Old 06-04-2015, 09:48 AM   #103
Need For Speed
KRAM36's Avatar
Thanks Chuck! Yep, that's were I found it the cheapest at. Also thanks for the part number on the connector.
2003 Boxster S
Old 06-04-2015, 07:18 PM   #104
Pdwight's Avatar
Tag
I just want to watch, this is a mod I would love to do to my car one day
Old 06-05-2015, 06:48 AM   #105
mikesz's Avatar
this is on my list of things to do. already have the guage cluster. right after i install the double din radio, center radiator, bilstein HD's and sway bars, and 18 rims.
99 Porsche Boxster
Old 06-07-2015, 06:24 AM   #106
KevinH1990's Avatar
While we are on the topic of the oil pressure sensor, I thought I would share a recent experience.
About two months ago the oil pressure gauge on my cluster pegged to the top while I was at the end of a long drive. The oil pressure warning light did not illuminate, so I thought it was a problem with the cluster, my wiring work or the pressure sensor. According to the 996 forum on Renntech, the pressure sensors are a known weakness. I replaced my sensor yesterday and that fixed the problem.
I've had my 996 cluster for over two years now and I still think this is a great mod. Whenever I see a picture of a Boxster with a 3-gauge cluster, it looks like something is missing. It is a little disappointing that the pressure sensor may fail occasionally, but I can live with that.
Good luck to anyone installing a cluster. While you are installing the pressure sensor, take good notes. You may be redoing the work in a couple of years.
Old 06-14-2015, 09:10 PM   #107
Need For Speed
KRAM36's Avatar
I have not got to installing the 996 cluster yet. I'm curious about the speedometer. My speedometer number stops at 175 mph with a few increments after the 175 and the 996 cluster goes to 200 mph. Will the 996 speedometer read correctly? Looks like I could just install the voltmeter and oil pressure gauges to my 986 cluster, would that be the better way to go?
Old 06-14-2015, 09:23 PM   #108
Chuck W.'s Avatar
Yes it will. No issues at all.
1995 Porsche C4 Cab
Old 06-14-2015, 09:30 PM   #109
Need For Speed
KRAM36's Avatar
Good to know Chuck, thanks for the quick response.
Old 09-12-2015, 05:14 PM   #110
EJ-Fresno's Avatar
Question regarding the circuit boards: can they be simply switched between 2 Boxster clusters, and still hold mileage and VIN? Or the new cluster will have to be reprogrammed no matter what?
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 09-12-2015, 11:53 PM   #111
Anywhere in the uk you can take a 986 to have the 996 cluster swap done for you with all the reprogramming
986wsm is offline   Reply With Quote
Old 09-13-2015, 12:43 AM   #112
The gauge faces and circuitboard are separate. If you're just looking to change your gauge faces, you can keep your original circuitboard and it will retain the VIN and mileage.
Old 09-13-2015, 03:25 PM   #113
EJ-Fresno's Avatar
So I can remove the circuit board from my current cluster and install it directly into the "new" cluster and it will be plug&play?
2006 V6 Mustang
2008 ML 350
Old 09-13-2015, 06:59 PM   #114
KevinH1990's Avatar
Yes
This would handle problems like scratched lenses or damaged dials.
Old 09-13-2015, 07:06 PM   #115
KevinH1990's Avatar
This thread How to - Upgrade to a 996 Instrument Cluster - How To - www.BoXa.net on Boxa.net has a post that indicates there is a person who can do it. They provided a link to this web site: Welcome to Reap Automotive Design
Old 10-20-2015, 09:54 AM   #116
mikesz's Avatar
I have the cluster, ordered the sender and wiring and still have directions you sent me a year ago. How did you cut the surround to allow for the 2 additional gauges?
99 Porsche Boxster
Old 10-20-2015, 05:30 PM   #117
KevinH1990's Avatar
Porsche Boxster 996 Gauge Cluster Upgrade - 986 / 987 (1997-08) - Pelican Parts Technical Article
Look at photo #4 in this article.
I have a black surround that I trimmed before I decided to use a 996 surround. If you are interested I'm willing to part with it. Based on what I can make out in your avatar, it appears that you have a red interior so I don't think it will work for you.
Old 10-21-2015, 09:06 AM   #118
mikesz's Avatar
Yes my interior is Boxster red, probably the biggest reason we got the car. I will let you know. I just purchased another surround to try to cut it as a guinea pig. I will try with the dremel and keep fingers crossed. Do you still have the programmer gadget you used to update the eprom on the new cluster? Did the wire come with the programmer or is there a special gadget needed to connect the programmer to the cluster?
99 Porsche Boxster
Old 10-21-2015, 09:29 AM   #119
WALDMEISTER
BRAN's Avatar
pelican parts mentions 986 AND 987 (-2008) for that swap mod?
i see...it is just the section of the technical articles...cool
Old 10-21-2015, 05:28 PM   #120
KevinH1990's Avatar
I sold the programmer to another board member who was also doing the swap. I think it has been passed on to several other board members. Why don't you post an ad in the parts forum and see if someone still has it.
You need an interface cable with SOIC Clip (SOIC stands for small outline integrated circuit) to attach the programmer to the circuit board. This looks similar to the one I had: 8-Pin Gold Plated SOIC Clip Test Clip with 0.1" Lead Spacing: Electronic Components: Amazon.com: Industrial & Scientific
You will also need the leads to attach it to the programmer.
