Old 12-25-2012, 07:46 PM   #1
Door speaker replacement
The stock door speakers should be replaced with component speakers and not coax correct? The size is 5.25 inch at a max of 3 inch depth. Was looking at Polk but any other recommendations? Just want something that works. System sounds fine but one door speaker is bust. Thanks
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 12-26-2012, 08:26 AM   #2
jcb986's Avatar
Thinking about doing mine too. Looking at Klipsch and Infinity.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 12-26-2012, 08:31 AM   #3
I'm decided on going with stock size (5.25") but not sure if the door speakers need to be coax or component type to be used as woofers. Also confused on the tech specs that is compatible with the existing Hayes amp 40x6.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 12-26-2012, 09:04 AM   #4
Having BTDT, unless you upgrade to a new amp w/ serious power... steer clear of 5.25" as their range is severely limited unless serious power behind them (40W isn't even close). You'll be extremely disappointed unless you pull out the stock "tuned ports" and make a baffle (links to DYI and template in archives here and on Boxster wiki) to fit 6.75 or 6x9" driver in there.
FYI - stock amp also has a crossover (no one that I've seen has been able to isolate the exact c/o point though). So, yes you want to go w/ either components or coaxial (and wire up only the woofer unless replacing stock amp).
Good luck
Old 12-28-2012, 05:21 AM   #5
Good luck
Most of time I'm listening to the songs off the ipod/iphone and it sound just fine (to me) even with the top down. Thanks for the input. I was confused on what I'd do with a coax as they come with the tweeter.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 12-28-2012, 05:48 AM   #6
jcb986's Avatar
Just contact Becker the manufacturer in New York and see what they say.
Old 12-28-2012, 06:27 AM   #7
Great. Keep us posted. Thanks
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
