Old 11-23-2012, 09:18 AM   #1
PSM Question
Hi all,
I'm new to this forum, though I use/read other forums regularly (Harley Davidson). I recently purchased a 2001 Boxster base and replaced the low beam headlights today with a better H7 bulb. Now I notice the the "PSM Off" light on on my instrument cluster stays lit, even when I press the PSM switch nothing happens. I checked all the relavent fuses and they look okay. Any thoughts?
aviscomi is offline   Reply With Quote
Old 11-23-2012, 11:41 AM   #2
Have your system scanned to find out what the PSM is doing, could be almost anything, but you won't know until it is scanned.....
Old 11-23-2012, 11:48 AM   #3
I did leave the headlights on w/o engine running for an extended period while installing the new bulbs. I'm just a bit concerned that I may have disconnected something accidently while installing them. The "PSM Off" light was fine prior to the headlight bulb install.
Old 11-23-2012, 12:45 PM   #4
Check your battery; sometimes the PSM and ABS lights are voltage related..............
Old 11-23-2012, 09:00 PM   #5
kls
Originally Posted by gvtheogioS View Post
Chuc buoi tuan vui ve
Cam on ban da post bai cho dien dan cua chung toi them sinh dong
Hay chia se that nhieu cho tat ca moi nguoi
Best regards
That's what I was going to say!
kls is offline   Reply With Quote
Old 11-23-2012, 10:29 PM   #6
Best regards
General translation:
Happy day. Thank you for your post to the forum and our more lively talk. Please share as much for everyone.
