Old 09-24-2012, 11:41 AM   #1
Ugh HELP -- temperature sending / sensor
Following a rad leak (and possible brief overheat lasting seconds only) ... my coolant temperature gauge went out -- suddenly stopped working and now does not work at all. Rad fans come on with a/c switch, not otherwise (fwiw, I needed to replace a bad radiator resistor to get the left side fan to work).
I have replaced the coolant temp sensor with no effect.
If its not the sensor what could it be? Help ... supposed to leave with this car on a trip in 1.5 days.
clueless1 is offline   Reply With Quote
Old 09-24-2012, 11:53 AM   #2
Sounds like you may have an air pocket in the system.............
Old 09-24-2012, 12:17 PM   #3
I replaced a rad (with flush and bleed) .... But If there is some way to test / remedy please let me know???
Old 09-24-2012, 12:19 PM   #4
JAAY's Avatar
Have you driven the car with the bleeder open. I changed my tank a week or so ago and have had the bleeder open since. I may close it soon. Good luck.
Old 09-24-2012, 12:44 PM   #5
Would this cause total gauge failure???
Any way to confirm?
Any other possibilities other than sensor (already replaced)
Old 09-24-2012, 01:40 PM   #6
If the air pocket is where the sensor is, yes........... You could also have a wiring problem, but that should be easy to test.
Best way to prevent air pockets is vacuum filling the system.
Old 09-24-2012, 06:43 PM   #7
hmmm ... somebody (i.e. wrench, not me) did not clear the obd code (there was no cel, you needed to plug in to read it ... p0015 i think). fortunately i figured that out before spending a bunch more dough on a 2nd wrench. temp gauge is now working.
a relief, needless to say.
i've got the bleeder valve open now ... is there any risk to driving it with the bleed open? how long should I leave it open for (both in days and miles if there is a reason to close).
all seems to be fine now ... is there anything else i wanna do to test before leaving on a long road trip?
thanks for all the help.
