Old 08-27-2012, 01:20 PM   #1
Ex Esso kid
Speed sensitive knock (one that increases frequency with vehicle velocity not a raise in engine revolutions) is likely rotational, in other words CV joint, wheel bearing, rotor pad, tire wheel.
Old 08-27-2012, 01:24 PM   #2
tonycarreon's Avatar
is it anything like what i experienced?
slow cruising:
constant noise 2 - YouTube
driving "at speed":
boxster constant noise from brakes - YouTube
Old 08-27-2012, 01:30 PM   #3
slow cruising:
driving "at speed":
Sounds like the first video, any idéa what that was?
tobiasr is offline   Reply With Quote
Old 08-27-2012, 01:49 PM   #4
jb92563's Avatar
Start checking the cheapest stuff first like the transmission mounts, rotors and CV/axle joints, or tire damage on the inside walls while your under there.
Once those are eliminated it will be much cleared whether its the transmission or not.
Transmission is not that likely unless somesone have been abusing it, but CV joints could be especially if the rubber boots have holes and letting abrasive material into that area.
Wheel bearings are another more common possibility.
Bar10dah: Love that Trunk Monkey, laughed for a good 5 minutes.
Old 08-27-2012, 04:22 PM   #5
I've got a bill staring at me on my desk for $7,600 to replace my Tip transmission ('00 base w/ Tip. 74k miles). Hope this isn't the situation you're in.
If you put it in gear up on jack stands (not that safe I know, but if done with car, can be done), have some put it into gear and check out the offending wheel more closely. Maybe take the wheel off and see if it still does it (again, on jack stands).
stateofidleness is offline   Reply With Quote
Old 09-20-2012, 04:45 PM   #6
DIY extremist
black_box's Avatar
sounds like a lot for a trans... $2700 was my cost to rebuild on a 6 speed, are tips that much more?
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
