Old 07-24-2012, 04:56 PM   #1
boxster battery flat
help my battery is flat and key trapped in ignition what can l do to get key out
snookerman is offline   Reply With Quote
Old 07-24-2012, 05:12 PM   #2
Jager's Avatar
No spare key??
If time allows you can go to the dealership and order a new key, all they need is the VIN.
Jäger
300K Mile Club
Old 07-24-2012, 05:17 PM   #3
battery flat
l have a spare key, cannot unlock hood to get to change battery all electric dead due to battery issue ??
Old 07-24-2012, 05:24 PM   #4
golonaus's Avatar
Pull the carpet by the fuse box
There is a frunk line
Just pull it gently
Done it today!!!
Old 07-24-2012, 05:24 PM   #5
Jager's Avatar
If you can get to the fuse panel, pull-off the cover. There is a terminal (Red) that you can pull out (extend) that you can connect + 12V power to. You will also have to connect the - 12V side of the power to chassis (ground).
Another option is to use the cigarette lighter, instead of using it as a power source, you are going to put 12V into it.
Jäger
300K Mile Club
Old 07-24-2012, 05:32 PM   #6
Also, jumping 12v+ to fuse C3 will release the frunk lever...assuming that you have levers and not switches. You didn't specify year/model?
Old 07-24-2012, 06:22 PM   #7
bar10dah's Avatar
The next time you're in your car, try turning the steering wheel left and right while trying to remove the key from the ignition.
bar10dah is offline   Reply With Quote
Old 07-25-2012, 06:04 AM   #8
Opposed to Subie Burble
Overdrive's Avatar
Likely the reason the key is stuck in the ignition. The steering wheel may be locked, which doesn't allow the key to turn without shifting the wheel.
Please let us know the year of your car. If it's a 2000 or later, you should have the positive terminal in the fusebox that Jäger mentioned. Otherwise, you'll want to do what golonaus mentioned.
-O/D
IMSR + RMS
Robbins glass window top
Old 07-25-2012, 07:42 AM   #9
Happens to me once in a while when i leave in the key - a flat battery. I just plug my winter float charger into the cigarette lighter for a few hours.
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
peterbrown77 is offline   Reply With Quote
