Old 07-25-2012, 07:04 AM   #8
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
Originally Posted by bar10dah View Post
The next time you're in your car, try turning the steering wheel left and right while trying to remove the key from the ignition.
Likely the reason the key is stuck in the ignition. The steering wheel may be locked, which doesn't allow the key to turn without shifting the wheel.
Please let us know the year of your car. If it's a 2000 or later, you should have the positive terminal in the fusebox that Jäger mentioned. Otherwise, you'll want to do what golonaus mentioned.
-O/D
IMSR + RMS
Robbins glass window top
