Old 02-06-2012, 08:41 AM   #1
Can't say I was lazy but two wheels were very hard to put on and take off. Those little metal tabs inside of the wheel where they fit on the hub were a pain. I took them out using Dremel and seem easy to put on and off now. I shall start using the torque wrench. Thanks for the inputs.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 02-06-2012, 09:46 AM   #2
Err the hub-centric tabs?
You can, and should, also use anti-seize paste between the wheel / rotor hat and also on the hub-centric ring. Sounds like you have some corrosion going on there. Better bet would have been to use a wire brush cleaning up the area as opposed to cutting them off...
Hopefully you won't get any vibrations...
Good luck
Old 02-06-2012, 10:11 AM   #3
Good luck
Are we talking about the same things? I removed the metal tabs (looked like lead tabs about 2-3 mm in height and about 3-4 inches long on the side of the wheel rims where they make onto the hub. Not the 3 tabs that are part of the hub.
The rear wheels' tab were gone or were probably removed. Don't have any vibrations or issues in the back. I had a use a crow bar everytime I had to remove the wheels. I guess I'll find out soon about the front. Would be a good reason to go after those 19" rims I've been dreaming of.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 02-06-2012, 10:57 AM   #4
Those sound like the stick on wheel weights used in balancing.
Old 02-06-2012, 11:15 AM   #5
Johnny Danger's Avatar
I've always used anti-seize on lug bolts . In addition, if some corrosion has occurred on the back of the wheel and hub, after cleaning it off with a wire brush , I'll put some on there as well .
