Old 01-31-2012, 12:33 PM   #1
2002 Boxster
Automatic rear spoiler question
I am able to raise the rear spoiler by pressing the button near my left foot. What I can't do is lower it by pressing the button beneath the other button. What I have to do is drive the car until it hits 45 or so and then slow down, then the spoiler lowers.
So I have a few questions :
1. Should the spoiler be able to come down by pressing a button ?
2. If yes, what do you think the problem could be ?
3. What speed does the spoiler automatically come up ?
4. What speed does it come down at ?
Terry
TerryT is offline   Reply With Quote
Old 01-31-2012, 12:37 PM   #2
jcb986's Avatar
I believe mine works the same way, will have to try and see.
Not sure if you really have a problem.
70 MPH
I believe it's around 40-45MPH
Old Hippie Young Heart
Old 01-31-2012, 01:32 PM   #3
WV Boxster
wvboxst3r's Avatar
yes spoiler should go down with button. It is the same button to put it up just pushed down instead of up. Problem - not really just need to remember that. The onlyreason I put mine up manually is to clean it. So you will needto take it for a spin after cleaning.
Speeds are up around 70 and down around 45.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 01-31-2012, 04:08 PM   #4
Going up you just need to press and let go. Going down you have to hold it down...
ohhh my is offline   Reply With Quote
Old 02-01-2012, 04:33 PM   #5
Guvs's Avatar
I have a dash board switch that lets me know when it's going up flashing Red LED at 75 MPH (in my Boxster) solid Red LED
when up, and it will only come down (flashing Red LED) when doing 50 MPH, unless I press my other retracting button at 60 MPH
Name:  spoiler warning light 002.jpg
although I think the spoiler on the Boxster is fantastic looking bit of kit , it does get a bit embarrassing if after you have put
your foot down to say join a motorway from a slip road and the spoiler comes up, you then slow down to 60MPH and your
spoiler is still stuck up in the "go faster mode" until your speed comes down to 50MPH when it will retract automatically,
you get what we call over here in the UK "Boy racers" seeing this (Spoiler up) as an invitation to a race against them in their
Vauxhall corsa's, so that is why I've put this button in to retract it at 60 MPH one touch manually works a treat.
Guvs.
Guvs is offline   Reply With Quote
Old 02-01-2012, 04:37 PM   #6
BYprodriver's Avatar
I know that's the correct up & down speeds but is that switch oem option?
Old 02-01-2012, 04:46 PM   #7
Guvs's Avatar
The one with the picture of a spoiler on it I got off eBay, the other one I mad up myself.
Old 02-01-2012, 05:49 PM   #8
WV Boxster
wvboxst3r's Avatar
How did you wire this up? Just guessing you extended the wires from footwell?
Old 02-01-2012, 06:11 PM   #9
Guvs's Avatar
The top one is wired up behind the dashboard to the red spoiler warning light block connector, all the instructions came with the switch, the other one is as you say a direct wire from the foot-well switch, but only on the down motion of the switch.
Old 08-22-2024, 11:07 PM   #10
There is also a version of that top indicator which is also a control switch. Costs a bit more, odf course. Same seller on eBay sells both versions.
FrugalGuy is offline   Reply With Quote
Old 08-23-2024, 02:03 PM   #11
Question Spoiler control?
Where do I go to find out how to get the aforementioned button?
HToddW is offline   Reply With Quote
Old 08-24-2024, 07:47 AM   #12
Probably a shill
A-NewName's Avatar
The one that was mentioned as being sold on eBay ...is sold on eBay.
https://www.ebay.com/itm/266841215477?
A-NewName is offline   Reply With Quote
Old 09-17-2024, 08:39 PM   #13
Ready-made switches
Try here. There are several versions, some just indicate, others also activate.
https://www.ebay.com/itm/266961167829
2004 Boxster S 50th Anniversary Edition #0000/1953
All stock.
Old 09-23-2024, 05:05 AM   #14
PLP
PLP's Avatar
Exactly what I needed.
Is the wiring same across all models/versions? Both - cars and switches.
PLP is online now   Reply With Quote
