Old 01-25-2012, 09:31 AM   #1
binkoba's Avatar
Telescoping steering column will not stay locked.
Hi
On my 2003 Boxster s, I wanted to adjust the steering column. I pushed the lever down, which was quite hard, and adjusted it out. I then locked the lever up. However the column will not stay put, it is hard to move, but under braking or accel it can move out or in.
Is this a common problem, I cannot find any posts about it. What am I doing wrong? I have pushed up very hard on the lock lever, and unlocked and relocked several times to no avail.
Ashley
Ashley
2003 Boxster S
binkoba is offline   Reply With Quote
Old 01-25-2012, 11:44 AM   #2
Originally Posted by binkoba View Post
Hi
Ashley
Ashley,
you may have to remove the plastic cover and tight the nut that is at the other end of the lever, it's pretty simple (once you can see the nut)
Old 01-25-2012, 07:27 PM   #3
Matt
MileHighBoxster's Avatar
It hasn't been common with the two I've owned. Try, if you haven't, slightly pushing on the steering wheel while pushing up on the locking lever.
Matt
2004 Boxster S, Guard's Red, 6 Speed
MileHighBoxster is offline   Reply With Quote
Old 02-07-2012, 12:03 PM   #4
fredpayne's Avatar
I have a 2003 Boxster S also, mine is doing the same thing as Ashley's, it won't stay locked. Did anybody find a solution? Thanks
2003 Boxster S - Orient Red
2010 Toyota RAV4
Past Toys
2000 Boxster - Ocean Blue
1994 Toyota Supra 320HP
1987 Porsche 944S
1983 Porsche 911 Carrera
1980 Porsche 911 SC
1976 Trans Am 455 Cu.In.
1962 Corvette Convertible
1957 Pontiac 2DR HT 421 Cu.In.
fredpayne is offline   Reply With Quote
Tags
steering column
