Old 01-08-2012, 11:00 AM   #1
DFW02S's Avatar
Better solution than a Porsche trickle charger ....
Use the Aventador.
DFW02S is offline   Reply With Quote
Old 01-08-2012, 12:01 PM   #2
jsceash's Avatar
Better solution than a trickle chargers is drive or run your car as many times as you can. I pull mine out of the garage and idle it until its warm then put it back.
Old 01-08-2012, 12:04 PM   #3
That's actually very bad for your engine.
Old 01-08-2012, 01:26 PM   #4
Ex Esso kid
That's a stretch, it's certainly not going to cause engine failure, but it's also not any better than a maintainer.
Old 01-08-2012, 10:16 PM   #5
DFW02S's Avatar
I guess the Aventador link was too subtle?
Old 01-09-2012, 03:20 AM   #6
Actually, no it isn't. UoA's show that running the car for short periods without warming it fully and driving it for at least 1/2 hour or so tend to break down the oil fairly quickly and load it with contaminents. Use a maintainer and leave it sit for the winter, your car will thank you for it...........
As for the Aventador, well that is overkill....
Old 01-09-2012, 08:29 AM   #7
^Thanks JFP you can always provide the technical answer better than the rest of us!!!
Old 01-09-2012, 08:43 AM   #8
jcb986's Avatar
If I haven't driven mine after a couple of weeks I will start let it idle until it reaches 180 degrees and then I go on a short drive of about 10 miles. Car is always on a maintainer. But, here in Florida the best convertible weather is upon us, so I drive it every weekend...top down of course.
Old Hippie Young Heart
Old 01-09-2012, 09:15 AM   #9
Correct me if I'm wrong but most mechanics I know only let their car idle for a minute or 2 tops. Letting it sit idle will actually warm the car up slower. Remember friction creates heat, you're supposed to drive slowly until the engine gets warm.
Old 01-09-2012, 09:52 AM   #10
Ex Esso kid
The Porsche manual that came with the 944 (which ran awful cold) always suggested starting the car and driving it slowly as you stated. I also believe that allowing it to idle and warm up will not in itself cause an engine to fail but to err to what you stated makes more sense. I don't see why letting it sit till spring is an issue either.
