Old 11-23-2011, 08:01 AM   #21
Originally Posted by Mrmaddbrad View Post
I'll say it again... A car with 200hp that weighs 3000lbs is a lot slower than a car with 200hp that weighs 2500lbs.... Like WAY slower...
Granted, unless you totally strip your car you're not going to get 500lbs out. But even 100lbs is feelable... Just take stuff out of your car! It will be faster..
And thats like $0 per hp lol. Cuz you're not gaining any horspepower or spending any money!! lol
If you want a car in a fast line, boxsters are not the car for you. If you want a great handling, fun, gorgeous car, then you should buy a boxster... Enough said.
True weight make a big difference. I think I read somehwere 0.2-0.3 second 0-60 improvement for every 100lbs lost. Problem with lowering weight-I drove without the engine cover carpet. I removed the carpet on top and the carpet behind the lower driver/passenger seat.
The car sounded horrible. It did not sound sporty at all. Those 5-10lb carpets make a huge difference in how good the engine sounds.
I thought of replacing front spare tire with Fix-a-flat spray, but idk how it effects my rim when trying to get a new tire? Has anyone used fix-a-flat? And I believe there are only 2 or 3 aftermarket rims for this car that are actually lighter than stock rims unfortunately.
ProjectM96 is offline   Reply With Quote
Old 11-23-2011, 08:07 AM   #22
[/B]
I can assure you that the above mentioned equipment alone will not achieve 20-25 hp . Not at the crank, wheels or otherwise .
Idk. I just looked at the dyno videos for the ECU upgrade and secondary cat bypass pipes from fabspeed motorsports on youtube. They did add roughly 17-20HP with the exhaust and ECU as well as a BMC Air Filter. Was guessing a Evo or Agency Power Cold Air Intake would add 2-3HP more than a BMC performance Air filter so that is how I reached 20-25HP.
As Fabspeed advertises.
8HP and torque for bypass pipes
10-12 HP for ECU Upgrade
Up to 5HP on BMC Filter(my guess is more like 1-2)
Old 11-23-2011, 08:56 AM   #23
Johnny Danger's Avatar
No offensive, but Fabspeed would love all of us to believe that their by-pass pipes and ecu program accomplishes those figures. Realistically, however, once a person has completed his or her upgrades, a good ecu tune more or less "tweaks" the air/fuel parameters . In turn, this can create better engine response and fuel efficiency . The actual gain is hp is negligible . As far as the effectiveness of bypass pipes are concerned, one can shed a good deal of weight from the vehicle, as well as open up exhaust flow which is caused by the restrictive nature of oem secondary cats. Again, this equates into a very little actual hp gain . It's probably the drop in BMC filter that gives things a slight bump . LOL !
Old 11-23-2011, 09:55 AM   #24
Is BMC really that good? I hear lots of good things about it. Much better than a K&N filter, right?
Old 11-23-2011, 10:05 AM   #25
I've had good results with one . However, nowadays I have the EVO high flow air intake on my vehicle . It's all about the sound !
Old 11-23-2011, 11:01 AM   #26
Opposed to Subie Burble
Overdrive's Avatar
^^^Note: Johnny is clearly stating that he is using the EVO intake purely for sound enhancement and not a performance enhancement for the car. One should always take the manufacturer's numbers with a grain of salt until you see it for yourself.
I would say, just my personal and not nearly expert opinion, that the most effective modifications are also some of the most expensive, and aren't going to net a ton of power. Jake Raby has developed some great improvements that both bulletproof the engine and increase its performance, but you're looking at a really high cost for it, at which point you're going to want to keep that car and get your money's worth. From what I see and read, Jake's done some incredible things, and for them you'll pay an equivalent price.
If you're not that attached to the car then for the same potential $20,000 you could be spending, you might as well combine that with a trade of your Boxster and knock out 1/2-2/3 of the cost on a new Corvette Grand Sport. It's no Porsche, but it's also not going to take much to pull an easy 50 more horses out of the thing when it already has more than double the Boxster's grunt. That was just for the sake of example.
What I didn't mention in my first post in this thread is where that plumbing change idea came from. Pedro's garage, where Pedro has come up with some great and pretty cost effective mods for the car, is another good place to look. Again, you're not going to get gobs of horsepower, maybe you'll get 20, but you'll get as much out of those horses that you do have as you possibly can when you start chipping away at Porsche's compromises. Have a look if you haven't already.
www.pedrosgarage.com
be forewarned, this site can really tax your computer's resources, so don't have too many things running at the same time when you go to it.
-O/D
IMSR + RMS
Robbins glass window top
Old 11-23-2011, 12:04 PM   #27
All too true re taking the carpets out. Just makes the car sound rough as hell, doesn't it?
I drove round in the stripped out track-prepped BMW for three years. No spares, no gunk, just winged it.
Actually, I've never had a flat...
Old 11-23-2011, 01:51 PM   #28
Haha well then take the weight from some where else :P Also, fix-a-flat is supposed to work if you also carry a bike pump and tire pressure gauge with you. The tire will still be flat after you fix the hole unless you reinflate it... But in reality, just get insurance that provides "free" towing. Tow it back to your house, take the tire to be fixed in another vehicle, call it good.
Flats are so rare, that i don't think the 20lb spare tire is worth it..... I've never had one, just avoid pot holes....
But the carrera 5 spoke wheels weigh A LOT less than the turbo twists that come with most boxsters...
Mrmaddbrad is offline   Reply With Quote
Old 11-23-2011, 02:08 PM   #29
Overdrive's Avatar
The oversight here is when one is travelling and isn't anywhere near home, which we have a few members on here who do, and is usually when life decides it's time for you to experience a flat tire. Jäger just recently went on a road trip over the summer that he shared with us on here, and he experienced a rear flat on the craptastic highways of OK not even halfway through his round-trip journey. And he had that car packed to the gills, but he didn't leave home without that spare.
One of those reasons why I don't beat myself up too much about not going with a 987...I still have a spare.
-O/D
IMSR + RMS
Old 11-23-2011, 07:05 PM   #30
If you're traveling why do you need weight reduction? Are we not talking about spirited driving/racing here? I mean why else would you need extra hp? For cruising down the highway? Its not like it takes 5 hours to put your spare tire in... Just put it back in when you're going to travel, if you're around town, take it out....
Stop being so irrational.... Or don't take my advice, and turbo/supercharge your car and wait for it to blow up...
Old 11-24-2011, 06:54 PM   #31
jaykay's Avatar
Where does a flat rear wheel go if you take it off?
Guess it is the GF or wheel??
986 00S
Old 11-24-2011, 07:45 PM   #32
Topless's Avatar
Just lean it back in the frunk. It fits fine. I always carry a full sized spare there on track days.
Old 11-25-2011, 09:11 AM   #33
Overdrive's Avatar
First, chill. Second, I'm not the one asking about turbo and supercharging my car, so ease up there, too. I was not saying you're wrong, I said there was an oversight in what you said. I may not work in an auto shop, but that doesn't mean you know everything there is to know already, either, so don't take everything said in response to you as a personal shot.
I was referring to this more than anything else from your previous statemt:
You don't think the 20lb spare is worth it, you've never had one, and your advice is just to avoid potholes? So unless I'm reading your statement wrong, you're saying you don't believe in having a spare because you can avoid all dangers to your tires, and you get the performance advantage of 20lb less in the car. And I'm being irrational? A flat tire can happen anywhere and for many reasons, and I'm sure you've seen them all, from running over nails or glass, to potholes, to who knows what the heck you ran over that sliced your tire apart. I've seen a golf ball-sized rock somehow embed itself in the sidewall of a co-worker's tire and break the bead, so when he came out of work he found his vehicle sitting on a rear flat with a rock jutting out of his tire. He has a 65 mile commute...make sense to have a spare then?
I've picked up nails several times, thankfully none with the Porsche, yet. Yes, it's a very infrequent occurence considering how long I've been driving, so I won't disagree with you there. All the nails my tires have picked up have been local, within 10 miles of home, and even in my own driveway. It just happens, and it sucks every time because there's a chance it compromised the tire. I've just been lucky that only 2 required a patching of the tire. And if my tire did go flat, I'd much rather take less time jacking my car up and throwing on a spare to get home on my own power than wait around for AAA or some other "free" roadside service. To me that's just invonvenient when I have it right there in front of me to DIY.
For tracking and any other racing, you are 100% correct, and I'm not disputing that every pound lost will count there. But you didn't stop there. You also said toss the spare out when you're around town. How much of an advantage is your local spirited driving experience really going to see without the spare tire in front? As you said, we're talking around town, right? How usable is that 20lb weight loss even in Sunday traffic? It might net you a thousandth or two of a second less approaching that next red light/stop sign...aka negligible. But sure, in the name of spirited driving, which just can't be had with an extra 20 lbs sitting up front, let's just say your statement's completely rational. I know that if I ever get a flat a mile from home I'll be glad I have my spare and jack ready to go.
Maybe you've got better roads where you live, but around here the roads are complete crap and only get worse as the winter comes and goes...you'd think someone mortared the streets sometimes (though we've got nothing on Boston, MA). I don't feel I need to be on a road trip to need my spare, because you never know what can happen on public roads.
-O/D
IMSR + RMS
Old 01-02-2012, 04:55 PM   #34
If anyone has thought of getting the Autothority Turbo Kit for the Boxster, I already called and asked for pricing.
8psi on stock internals(not good for our high compression engines) and promise of 380HP after they are done with it.
$30,000 for the kit. That can't be justified. Turbo Kits on normal cars cost $1000-5000.
Old 01-02-2012, 05:49 PM   #35
Ah, you must have spoken with Minh . The kit is offered through TTP in Germany . The proprietor's name is Pietz, and he's the penultimate sh**t head next to Fabian Roock.
LOL !! Stay away ! It will be 380 hp alright - just in time for the 4th of July !
