Old 07-16-2011, 11:22 PM   #1
Previously in similar situations, I've used a metal chisel to cut the nut on both sides and then pull/pry it off. Then clean up the threads using the correct type/size die. Otherwise, you may have no option but to replace it.
Old 07-17-2011, 06:08 AM   #2
Craftsman makes a tool
Craftsman makes a pretty cool set of 'nut extractors'. for lack of a better name.
Same concept as an EZ out, except meant to grab the outsode of the nut rather than the inside of a drilled hole.
Looks like a socket attachment, but has tapered teeth inside. you tap it on the nut with a mallet and remove with a wrench.
http://i1215.photobucket.com/albums/...dall/Car-1.jpg
2001 S Speed Yellow, matching interior, German Plates!!
Iflylow is offline   Reply With Quote
