Old 06-19-2011, 09:10 AM   #1
IMS replacement; some technical questions
This weekend, I changed IMS bearing, clutch, RMS, water pump, thermostat, belt, and repacked CV joints.
I have 60K on my '01 S, and the IMS bearing looked brand new. Also, the clutch was a Sachs, with at least 60% left on it. Makes me think both were changed by the previous owner (I bought it with 40K).
Two questions: I need to secure the crankshaft in order to tighten the flywheel bolts. I used the pin in the front pulley to secure the crankshaft at TDC. is this pin strong enough to torque the flywheel bolts?
CV boots: the ones I got from Pelican were significantly smaller than the originals. Are there different sizes between the base and S models?
BTW, the tools supplied by LN Engineering worked incredibly! The actual bearing replacement took about 30 minutes.
http://i1215.photobucket.com/albums/...dall/Car-1.jpg
2001 S Speed Yellow, matching interior, German Plates!!
Iflylow is offline   Reply With Quote
Old 06-19-2011, 09:18 AM   #2
Porsche acutally makes a reasonably priced flywheel lock that does an excellent job, but most make do with the pin up front, a bellhousing bolt and a pry bar.
Old 06-19-2011, 10:06 AM   #3
Ok, I will try it, thanks.
I actually need to hit the dealer on monday because I messed up the RMS I will see how much the flywheel lock is.
Old 06-19-2011, 10:14 AM   #4
Part # 000-721-953-81, if memory serves (I've had mine for several years), it was about $15 or so.
Old 06-19-2011, 12:58 PM   #5
Yes. The LN engineering tool will work fine for that. I used it with no problems.
Mike_Yi is offline   Reply With Quote
Old 06-19-2011, 08:37 PM   #6
Jager's Avatar
CV Boots: Yes the 2001 base model has smaller boots. In fact the base axles use 8mm bolts to the transmission output shaft and the S model uses 10mm bolts, significant difference.
