Old 05-15-2011, 08:10 PM   #1
trans/diff. fluid change
Can anyone tell me where or what the transverse panel is ? I need to change my 75/90 lube after replaceing axles,seals etc. and can't find the plug, it is under this panel.
Thanks in advance
ACBOB
acbob is offline   Reply With Quote
Old 05-15-2011, 08:41 PM   #2
Steve Tinker's Avatar
The panel is the large alloy triangulated section bolted to the chassis rails. You have to remove the plate to access the gearbox drain plug.
Note that the plate is a very tight fit over its retaining studs and may need a little (gentle) persuasion to remove....
2001 MV Agusta F4.
Old 05-16-2011, 10:44 AM   #3
Looks like this:
