Old 04-16-2011, 03:33 PM   #1
DFW02S's Avatar
Oil drip, what does it mean?
I'm fairly certain some of you have the answer to this issue, I found a couple of oil spots on the garage floor and they seem to be dripping from the shift mechanism.
Thanks for your input on what the problem might be.
DFW02S is offline   Reply With Quote
Old 04-17-2011, 06:30 AM   #2
audisnawb's Avatar
Send a message via AIM to audisnawb
Im going to go out on a limb here and say its an oil leak.......
I kid, I kid- but seriously- Im not sure WHAT it would be coming from, RMS seems to be a common one.
PRESENT:
SUMMER FUN: 1999 986 Porsche Boxster Metalic Black on Sierra Beige
WINTER BEATER: 2007 BMW 530xi
PAST: 2000 986 Porsche Boxster Biarritz White on Sierra Beige
audisnawb is offline   Reply With Quote
Old 04-18-2011, 01:44 PM   #3
jaykay's Avatar
I would have a look and see if is coming from the engine transmission interface. This could mean an RMS or ims problem; the RMS being right above the ims.
Oil coming from this area should be investigated as soon as you can and hope that it is an RMS problem and not the other.
986 00S
Old 04-18-2011, 08:09 PM   #4
laphan's Avatar
Is your car S model with 6 speed manual?
If yes, it might be the infamous shift linkage leak.
http://www.renntech.org/forums/index.php/topic/22219-shift-linkage-shaft-leak/
laphan is offline   Reply With Quote
Old 04-19-2011, 09:25 AM   #5
DFW02S's Avatar
Thanks jayjay, I had them done a few months back so I hope it's not either.
And I sure in heck hope you're wrong laphan, but that's a good tip, thanks.
I cleaned up the area this morning, let's see what happens.
Old 04-28-2011, 08:40 PM   #6
DFW02S's Avatar
Tip of the hat to laphan for a good call!
Then 5 days later the AOS goes at the track.
Good times with the Boxster!
Old 04-29-2011, 08:39 AM   #7
laphan's Avatar
Sorry to hear that. But if the leak is not that bad, just keep on eye on the trans oil level and fix it later when you need to have clutch, RMS, IMS work (trans need to be removed).
I replaced my AOS even when it still worked early this year. Next is water pump
Old 04-29-2011, 08:52 AM   #8
DFW02S's Avatar
Picking it up today. I had the shift shaft done too.
IMS, RMS, clutch, water pump, motor mount all done within the past 3k miles.
It should last forever now, right? LOL
Old 04-29-2011, 09:03 AM   #9
laphan's Avatar
Its a boxster, you never know
I thought I was done after new battery, IMS, RMS, clutch... and.... low and behold ... my rear plastic window cracked and headlamp sprayer nozzle broke
Old 04-29-2011, 09:31 PM   #10
DFW02S's Avatar
..... I thought I was done after new battery, IMS, RMS, clutch... and.... low and behold ... my rear plastic window cracked and headlamp sprayer nozzle broke
laphan, I gave you props for a good call, why you gotta' curse me?
Old 04-29-2011, 09:57 PM   #11
laphan's Avatar
NO, I did not curse you but we both are in boxster curse.
Luckily our car drives so well so I can justify to put up with these repairs...
